The book of codes
SoDoWarts
Has thanked: 1 time
The book of codes
Post by SoDoWarts »
Howdy -- is there some resource out there that lists all the OBD codes for the C70 convertible 2000? Thank you!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
I can't remember if 2000 C70 was M4.3 or what, but start here. https://www.matthewsvolvosite.com/volvo ... 5-to-1998/
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
A 2000 C70 should be ME7.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
SoDoWarts wrote: 13 Nov 2021, 12:55 Howdy -- is there some resource out there that lists all the OBD codes for the C70 convertible 2000? Thank you!
VIDA.
RickHaleParker
Chuck W wrote: 13 Nov 2021, 13:13 A 2000 C70 should be ME7.
It is ME7 but that is the ECM only. He wants all the codes. There are 16 control modules on the 2000 C70.
Has thanked: 1500 times
Been thanked: 3812 times
For ECM codes all P0xxdx codes are SAE standard so they are preserved across makes.
Corrected below, thanks RHP
RickHaleParker
abscate wrote: 13 Nov 2021, 14:23 For ECM codes all P0xxx codes are SAE standard so they are preserved across makes.
x0xxx, x2xxx & x3400 - x3499 are SAE Generic.
1st digit identifies vehicle subsystem
  • P - POWERTRAIN
    C- CHASSIS
    B- BODY
    U- NETWORK
2nd digit identifies code type
  • 0, 2 - SAE Generic
    1- Manufacturer Specific
    3- SAE or Manufacturer Specific (Code Dependent)
    x3000-x3399 Manufacturer Specific
    x3400 - x3499 SAE Generic.
3rd Digit Identifies Specific Vehicle System
  • 0 - Fuel, Air Metering & Auxiliary Emission Controls0-
    1 - Fuel and Air Metering
    2 - Fuel and Air Metering
    3 - Ignition System or Misfire
    4 - Auxiliary Emission Controls
    5 - Vehicle Speed, Idle Control, and Auxiliary Inputs
    6 - Computer and Auxiliary Inputs
    7 - Transmission
    8 - Transmission
    9 - Transmission
    A- Hybrid Propulsion
    B-F SAE reserved for future use
4th and 5th digits identify the specific fault with the system. Too many to list here.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
^ I never knew this. Very cool !
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
The internet is a good resource for identifying most fault codes. You do have to sort the meaningless results from the good information.
I’m pretty sure Denzel Washington made a movie on this topic
