2006 Volvo S60 AWD - turbo replacement
Has thanked: 312 times
Been thanked: 818 times
That's good to confirm the snap ring pliers are not for removing the turbo, thanks.
Maybe what jonesg is also implying is that the turbo may indeed need work given all that smoke and the sudden onset. Clogged PCV would creep up on you gradually. That "circle clamp" thing is called a V-band clamp. Holds the turbo to the exhaust flange housing, the piece that sits between the turbo and the exhaust. But anyway, you need to do some diagnosis.
Agreed and more with jonesg on the drain tube gaskets, this is a key point - if you pull the turbo then *absolutely* change both ends, paper gasket on one and circular rubber seal on the other. The drain tube seals are by far the most common oil leak related to these turbos. But if we're taking parts here I'd also pick up new copper washers for the lines, and plan on replacing all vac lines to the turbo unless they are recently done.
TisMe
Year and Model: 2001 & 2004 XC70
Has thanked: 42 times
Been thanked: 18 times
Post by TisMe »
Someone on the forum once recommended, if you're overhauling your vacuum lines, to get this hosing. I haven't used it yet but seems quality, it's sitting in an oily corner for when I do the deed.
Has thanked: 1613 times
Been thanked: 4077 times
I think it’s all 5 mm hose on the turbo lines, isn’t it?
TisMe
Post by TisMe »
abscate wrote: 18 Nov 2021, 08:30 I think it’s all 5 mm hose on the turbo lines, isn’t it?
Great catch, thanks for the correction! I'm trying to reverify but coming up short. The op could have been referencing a different application for the 4mm and I mixed signals. Maybe someone else will care to pitch in.
I'm finding reference to 7mm, 6.6mm, and 5mm all for different uses on the car. 5mm sounds correct for the general overhaul.
This place http://www.siliconeintakes.com/ sells a nice thick-walled hose though I agree other sources are likely good. Anyway, they offer even number sizes e.g. 4-6-8-10mm. I use 4mm for the turbo lines.
4mm is good for most of the lines https://www.matthewsvolvosite.com/forum ... hp?t=65002 and 5mm may work too, I just haven't tried it.
notny41
Year and Model:
Post by notny41 »
I hate to even start the thing because it smokes so much. I will try to get the PCV glove test done on it. Assuming it is the turbo, is it ok to run the engine even though all of that smoke is coming out?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
its steam, not smoke unless the steam dissipates and turns into blue smoke which would be oil. Mine did both.
You have to run it to diagnose, have you checked the compressor for runout or shaft slop?
Also test proper operation of waste gate . (youtube).
IPD sells 3 color coded turbo vac hose kit,
red,yellow,blue hoses makes it easy to keep track of whats what.
notny41
Year and Model:
Post by notny41 »
I haven't check the turbo yet. So you are saying it would be fine to run for short periods of time as long as a person keeps an eye on coolant level?
Coolant level and the oil level
Keep your foot out of the pedal and drive it like it’s loved until you sort it out
TisMe
Post by TisMe »
As long as you don't redline it in your driveway while diagnosing, you're not going to do anymore damage than what's already manifest. If your PCV system is clogged, your main worry is blowing engine seals. That primarily happens when the turbo kicks in and heavy pressure is pushed back through the crankcase due to your clogged PCV. Your cam and crank seals, which are no huge deal to replace, will likely blow before the main seal.
The main seal blowing is a game-changer, expensive OR time-consuming, which is why it's great you're doing this now.
