Coolant dye - which one to use?
Geevs
Year and Model:
Has thanked: 9 times
Post by Geevs »
Hi all,
I'm trying to find a coolant leak in the engine bay, I know it's not coming from the heater core. What kind of UV dye is compatible with Volvo OEM blue coolant? Do I need to flush/replace the coolant after testing? And will the dye change the color of the coolant?
This is the UV dye I can get from my parts store:
https://www.cpsproducts.com/product-details/b483906/
Thanks!
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
Geevs wrote: 21 Dec 2021, 19:07 Hi all,
Thanks!
what does it matter if you drain it anyway.
gonna have to drain the system to fix it.
You also need the uv glasses and UV light.
a common source of leaks is the expansion bottle, look for white chalky dust , the corners fatigue and will show tiny cracks.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Drying coolant will leave a whitish residue, spotting a leak is easy w/o additives.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Head to the Kitchen and cook up some Quantum dots. Figure out the dilution rate by experiment. Then dope the coolant system with the Quantum dots at the dilution rate. Quantum dots diluted to the correct ratio makes a non-toxic trace dye.
vtl
Post by vtl »
Also... Pull the spark plugs and inspect them / look inside the cylinder. Coolant leaking into cylinder will wash everything to a like new, shiny shape.
