Is my camshaft f****ed?
Is drilling out and (if needed) re-tapping my best option here?
Has anyone else ever experienced this? I can’t really find anything about it on any forums anywhere.
Thanks in advance for your help!
It's been my experience you have to be very careful with hardened extractors and drill bits, you don't want to break off anything hardened in the bolt drill hole.Sykonica wrote: 22 Dec 2021, 16:01 I was working on my 01 XC70 today. When trying to replace some cam seals, I was installing the locking tool, and after gently tightening the (cheap) bolt, it snapped inside the camshaft on the intake side. After trying to back it out with several extractors, it’s still stuck. The plan is to drill out the bolt and see if I need to re-tap the threads to install the locking tool. I’m hoping someone here can answer some of the following questions:
Thanks in advance for your help!![]()
firstv70volvo wrote: 22 Dec 2021, 17:35It's been my experience you have to be very careful with hardened extractors and drill bits, you don't want to break off anything hardened in the bolt drill hole.Sykonica wrote: 22 Dec 2021, 16:01 I was working on my 01 XC70 today. When trying to replace some cam seals, I was installing the locking tool, and after gently tightening the (cheap) bolt, it snapped inside the camshaft on the intake side. After trying to back it out with several extractors, it’s still stuck. The plan is to drill out the bolt and see if I need to re-tap the threads to install the locking tool. I’m hoping someone here can answer some of the following questions:
If you decide to drill into the broken off bolt try using left handed drill bits because if the bolt isn't bottomed out and tightened too tight you can get lucky sometimes and just drilling with these type of bits will back out the broken bolt out. Sometimes it helps to use flat headed punch smaller than the diameter of the bolt and give a rap or two before trying to extract it. All this assumes the bolt is broken off inside the threaded camshaft hole, which means you need to careful with any of the expose threads in the camshaft. If you get the broken bolt to turn you don't want any damaged threads working against on the way out. Use a drill bit as large as possible with enough room not to drill outside the diameter of the broken bolt and into the threads of the camshaft and keep in mind you it's difficult to get it perfectly centered and drill perfectly straight. Good luck
https://www.amazon.com/Neiko-01925A-Ext ... 6046&psc=1
That’s correct.
I did this EXACT thing the same way you did. I tried reverse bit, extractors, drill with a 90 degree angle fitting.Sykonica wrote: 22 Dec 2021, 16:01 I was installing the locking tool, and after gently tightening the (cheap) bolt, it snapped inside the camshaft on the intake side. After trying to back it out with several extractors, it’s still stuck. The plan is to drill out the bolt and see if I need to re-tap the threads to install the locking tool.
No, there is a higher chance a charging rhinoceros will ruin it.Given that the camshaft spins at high speed for long periods, is there any danger of having it be slightly out of manufacturer tolerance (either from part of the bolt living in there permanently or accidentally cutting out some of the threaded portion upon extraction)?
