Im still sorting out the door lock situation for my 2013 S60. Computer says "DOOR OPEN", thus cannot lock the car. You can manually lock the drivers door (the door affected by this), but the remainder of the doors cannot be locked! I'll assume it's the door actuator or a break in the wire in the door frame.
Does anyone know what color wire in the bundle is the door lock? If I open the cable wrap, it will just be a mass of wires!
Also...in researching for the actuator, it states "Deadlocked' as a filter. What does that mean? Is my door one of those? Heck...I just want to fix the darn door...it's 40 degrees outside and I will be working in the cold...
Door lock issue
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
One dumb question:
When you open/close the door in question (with all other doors closed) does your interior lights' status change (On/Off)?
I am also looking for your electrical schematics...
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
Okay,
This is your Driver Door diagram for LHD with Central Locking
On the print:
- 3/80 is your door switch
- 3/126 is your door control module
- 6/36 is the lock actuator
See the second page for wire colours.
Hope this helps
On the print:
Hope this helps
Central Locking 2013 S60 LHD.pdf- (49.32 KiB) Downloaded 162 times
Wire Colours.pdf- (47.75 KiB) Downloaded 120 times
2015 BMW 335i
2015 BMW 335i
