Throwback to the EPA mileage estimates which were always way too high....
Your mileage may vary....
A polite way of saying that is my experience but not to be taken as gospel..
Bouncy Bouncy - Need Rear Shocks
- Has thanked: 1504 times
- Been thanked: 3817 times
Re: Bouncy Bouncy - Need Rear Shocks
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
"You Might Maintain Volvos?
You Miserably Maintain Volvos?
Yuck, My Moldy Volvo?"
Third one scares me!
Nice to be down the street from Voluparts!
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
Trying to picture what you mean here. For starters, why did you choose to use ramps instead of a jack stand? Isn't it much easier to remove that bottom bolt when the shock is fully extended and not bearing the vehicles weight?cn90 wrote: ↑05 Mar 2022, 08:43 LOL,
My rear shocks were bad at 12y/100K...
I replaced with Bilstein B4 rear shock, about $50/each online.
Just drive the rear wheels on wood ramps.
During insertion, put the plastic tube in first, then the shock (since most of us don't have a lift like dealer, shops etc.).
If you heat the "nut" side with propane torch, it will come out easily bc the heat melts the factory red Loctite.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Been thanked: 471 times
@br0dy519,
- I am getting old, I avoid jacking up the car and jackstand bc it takes time and effort.
With wood ramps: nothing to do, just drive the car up the ramps.
- Even with the car on ramps, the brand-new Bilstein shock barely sticks out 1 inch below the control arm.
I just have to push it up a bit and the bolt slides right in.
The idea of replacing the shocks while the car is on the ground has been documented in both P80 and this (P2) forums.
It is much more simple with the wood ramps...
- br0dy519
Cool thanks for the tip. I'm gonna plop some cheapo FCS shocks and new Mevotech mounts in there and see if it helps my rear end rattle. I just got a new set of steel ramps this week so this may be the first job on them. (once the snow clears)cn90 wrote: ↑11 Mar 2022, 21:31 @br0dy519,
04s60 2.4
04xc70 2.5t
04xc70 2.5t
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
I ended up installing the KYB Gas-A-Just shocks. Seemed to be decent quality, middle of the road units - made in Japan. A short test drive, which included several speed humps, revealed a much nicer ride with no bouncing or rattling.
I performed the R&R with the rear wheels up on ramps.
- br0dy519
I’m eyeing those too. Good price and well reviewed brand. How were your mounts on inspection? I think i’ll do my end links while I’m there too. Need a nice temperature day to inspect all these items.chrism wrote: ↑13 Mar 2022, 19:31 I ended up installing the KYB Gas-A-Just shocks. Seemed to be decent quality, middle of the road units - made in Japan. A short test drive, which included several speed humps, revealed a much nicer ride with no bouncing or rattling.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
@br0dy519,
Since you are in Windsor, you can order to Detroit and pick it up there.
Bilstein B4 rear shock is about $75/each or $150/pair.
US dollars...
LT warranty...
US dollars...
LT warranty...
- br0dy519
Don’t get me started on Canadian entry requirements during COVID….
Rockauto has amazing shipping logistics where all of the duties are included for an extremely reasonable price. They’ve been a lifesaver the past two years during all of the border nonsense.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
