Auto Transmission Topic is solved
Daria
Post by Daria »
Hi All,
My question is: I have a '94 850 with 113K and the other day I backed out of my driveway, put it in drive and it would not shift down; so, I stopped and put it back in park and then in drive again and it shifted fine. Any idea - should I start shopping for a new car?
Thanks,
Daria
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Check your trans. fluid level, color and smell. It should be orange or pink, with no burnt smell.
https://www.matthewsvolvosite.com/images ... ne_bay.jpg
You may want to change the fluid if it fails any of these tests.
Also -> Amazon link
dan_burdock
Year and Model:
Post by dan_burdock »
Did you get a flashing arrow on the dash if so try PNP switch, sounds like the same thing that was happening to 850t5r. If it happenens again see if the ecu throws up any codes.
Dan
