Hi Everyone,
My 98 V70 GLT has the wires ripped out of the connector on the front ABS wheel speed sensors. Is there a connector or pigtail that I can purchase to repair it? I tried female bullet connectors from the local parts store but they don't seem to fit correctly.
Thanks in advance!
Dave
ABS sensor connector
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I don't know, but you could try a junkyard for a "new" connector.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
If you mean the connectors in the sensor itself, I would replace the part. If it's the portion in the harness pigtail, a junkyarding you should go.
Even an iffy electrical connection down there will spook the ABS module - among other things.
- Has thanked: 2197 times
- Been thanked: 1850 times
The ABS wiring has a resistance value range they can operate within. If you add items into the wiring it likely will take it out with these values. Replace the part with new or used as suggested above.
The cables are still out there but getting harder to find. It is an ATE branded part:
https://web.tecalliance.net/ate/en/home ... Country=de
This allows you to look up the ATE part number so it should help to find the OEM part. Most I found were in Europe.
- 1510 Views
Last post by mecheng
- 1050 Views
- 27 Replies
- 14255 Views
Last post by Orchid70
- 2268 Views
Last post by 850oldschool
- 921 Views
Last post by jimmy57
