2004 XC90 NO brake lights
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Re: 2004 XC90 NO brake lights
Post by chitownV »
MARCUSBUTZIN wrote: 16 Apr 2022, 18:37 2011 XC90 I have third brake light (upper center ) working but not either side. Is the relay on the left corner interior? Does anyone know if there is a brake light relay under the hood? Advise please!
If the 3rd brake light turns on with the brake pedal, then your brake switch is good. Could you tell us if there was anything that led to the brake lights not working? I ask in case the issue happens again.
Did you recently change the battery?
Did you notice any water in the rear areas?
Were bulbs recently changed or did you have LED bulbs installed?
Any rust in the bulb sockets?
Is it only brake lights or are the parking lights (tail lights), license plate light, and/or reverse lights also out?
Bookmark the site linked below so you can find information next time. It's basically the online VIDA for info.
As mentioned, check Fuse #30 for the brake lights. Here is more detail & diagram information: https://workshop-manuals.com/volvo/xc90 ... age_16601/
If you also have tail lights that are out, then it's Fuse #2: https://workshop-manuals.com/volvo/xc90 ... age_16596/
Good luck.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
MARCUSBUTZIN wrote: 21 Apr 2022, 15:54
Krons wrote: 19 Feb 2022, 16:59 I'd chase the voltage...any power at the relay? Possible replacement relay is bad.
Location of the relay please, I have a 2011 with only the center section up working (3 rd brake light ) is the relay under the hood? I looked at the small circuit board in the left rear corner ( the baggage area, trunk if you will ).
Sorry for the delay. I believe your operators manual has the diagram with the brake relay location. It is in the panel on the left side in the trunk. Worst case swap relays til it is fixed and you found the right one.
08 C702.5T (sold)
The non-Swedes:
allpoint
Year and Model: 2003 XC-90
Post by allpoint »
I had the Check Brake Lamp error on my 2003 XC-90. It started out intermittent but progressed to permanent failure. Third-eye brake lights works, but other two do not I accessed the REM (rear electronic module) behind the left cargo panel. Replaced the relay switch that feeds the brake lights. On my vehicle it was the middle one (blue one in photo). Note: the original relays were black. I used Volvo part 30765042, which is a newer (solid-state) version of the 2003/2204 switch. This resolved the issue.
