Clunking Noise Topic is solved
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Clunking Noise
Post by 02V70 »
When driving, I hear a clunking noise coming from the right front when driving. It usually happens when driving over bumps.
Here is a video that has the noise. There is some other knocking noises (the keys knocking against the wheel) but it happens two distinct times, and sounds sort of like water draining.
VolvoNoise.mp4
(1.23 MiB) Downloaded 210 times
I looked at the bushings, and found this.
It looks broken, so would this be making the noise? What is it called, and how would I replace it?
Also, this is what the top of the strut looks like is this normal?
The other side looks similar.
2002 v70 X/C 288k miles
Has thanked: 1509 times
Been thanked: 3827 times
It looks like you need new strut and ball joints, both sides
About $500 in parts
$500 labor, except in CA, where it will $900 labor
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 609 times
Post by vtl »
Smells like front suspension rebuild coming soon. It is actually not difficult, maybe 5% of your engine adventure. Need a good clamp-style coil compressor, ~$90 on ebay. FCP has a kit with all the hw needed, around $600.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
vtl wrote: 13 May 2022, 05:17 ….Need a good clamp-style coil compressor, ~$90 on ebay….
A lot of the auto parts stores have spring compressors available in their tool loan program. You actually “buy” the tool and then you get a full refund upon returning it.
02V70
Post by 02V70 »
abscate wrote: 13 May 2022, 02:48 It looks like you need new strut and ball joints, both sides
About $500 in parts
Do I need to get new coil springs too? Or does the strut include that?
BlackBart
Has thanked: 928 times
Been thanked: 885 times
Post by BlackBart »
No - the springs come off the old strut and go back on the new one, with a new bearing / seat on top.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Curious how did you guys diagnose the strut? The balljoint looks obvious to me. But I haven’t seen the video.
You need to get new upper strut mounts too since you’re already in there.
04s60 2.4
04xc70 2.5t
02V70
Post by 02V70 »
I am replacing the lower ball joints, and it looks like some of the bushings for the lower control arm are not good. Can I replace the control arm bushings by themselves, or should I just replace the whole control arm?
I believe it’s…..
Aluminum control arms, replace bushings/ ball joints
Steel control arms, replace in whole.
BlackBart
Post by BlackBart »
On my P2 I installed alum control arms with bushings, and a new balljoint. All ipd HD kit.
