Threadlocker for suspension bolts.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I am replacing the lower ball joints, and it looks like a bunch of the bolts have red colored thread locker on it. I only have permatex medium strength blue threadlocker. Will this work, or do I need to buy the red high-strength threadlocker?
2002 v70 X/C 288k miles
Has thanked: 1505 times
Been thanked: 3818 times
Volvo service
Note! Screws coated with locking fluid or sealant must be replaced with new when reinstalled.
Always use new screws and nuts when angle tightening. Any exceptions to this rule will be indicated in the method.
Angle-tightening in tight spaces. See Screwed joint, torque/angle tightening See: Description and Operation\Screwed Joint, Torque/Angle Tightening.
Been thanked: 472 times
Post by cn90 »
Blue Loctite is fine. Don't worry.
Just use the correct torque.
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
3 ugga duggas tight.
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
I have no idea if any mechanic use locktite which is why most new parts have it preinstalled for this very reason. afaik they all just ugga dugga to get it out of the shop if it gets reused.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
ugga dugga is my favorite automotive phrase.
What are people's thoughts on caliper attachment bolts? Anti-seize? Thread locker? It's not on a Volvo. It's not going to be driven a ton, and not in the snow, so I don't see any corrosion problem.
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
I would just be sure to torque to manufacturer specs.
BlackBart wrote: 30 May 2022, 13:45 ugga dugga is my favorite automotive phrase.
I use the two new ones that come in the Volvo rotor kit, paradoxically priced at the higher price of the Bosch kit , with the delta being the cost of the two Volvo bolts
8)
In snow country you fight the fact that thread locker and antiseize are mutually exclusive. In dry country, blue thread locker makes sense if you aren’t sure of the torque or fastener quality
jonesg
Post by jonesg »
I removed a front caliper yesterday, "tight as I can" is how it went back. I don't use thread locker, bad experience not being able to remove the bolts again due lack of space to get leverage and no room for an impact.
The long volvo water pump bolts with red sealer on the thread isn't red loctite thread locker, they'd never come off again if it was.
