Threadlocker for suspension bolts.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I am replacing the lower ball joints, and it looks like a bunch of the bolts have red colored thread locker on it. I only have permatex medium strength blue threadlocker. Will this work, or do I need to buy the red high-strength threadlocker?
2002 v70 X/C 288k miles
- Has thanked: 1505 times
- Been thanked: 3818 times
Volvo service
Note! Screws coated with locking fluid or sealant must be replaced with new when reinstalled.
Always use new screws and nuts when angle tightening. Any exceptions to this rule will be indicated in the method.
Angle-tightening in tight spaces. See Screwed joint, torque/angle tightening See: Description and Operation\Screwed Joint, Torque/Angle Tightening.
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
I have no idea if any mechanic use locktite which is why most new parts have it preinstalled for this very reason. afaik they all just ugga dugga to get it out of the shop if it gets reused.
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
ugga dugga is my favorite automotive phrase.
What are people's thoughts on caliper attachment bolts? Anti-seize? Thread locker? It's not on a Volvo. It's not going to be driven a ton, and not in the snow, so I don't see any corrosion problem.
- Been thanked: 1000 times
I would just be sure to torque to manufacturer specs.
I use the two new ones that come in the Volvo rotor kit, paradoxically priced at the higher price of the Bosch kit , with the delta being the cost of the two Volvo bolts
In snow country you fight the fact that thread locker and antiseize are mutually exclusive. In dry country, blue thread locker makes sense if you aren’t sure of the torque or fastener quality
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
I removed a front caliper yesterday, "tight as I can" is how it went back. I don't use thread locker, bad experience not being able to remove the bolts again due lack of space to get leverage and no room for an impact.
The long volvo water pump bolts with red sealer on the thread isn't red loctite thread locker, they'd never come off again if it was.
