Uneven brake pressure front and back.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Both cables are probably seized. Do you just say parking brake overhaul because of the rust cn90 ? I don't see how that rotor wear would have anything to do with the parking brake.
04s60 2.4
04xc70 2.5t
goldxc70
Year and Model: XC70 2004
Has thanked: 27 times
Been thanked: 3 times
Post by goldxc70 »
Herb Goltz wrote: 10 Jun 2022, 07:55 Man, those are some rusty rotors (even by Ontario standards!)! Very poor pad to rotor contact. Having a similar issue with my 2006, just bought pads and rotors. I have been buying pads and rotors from Max Advanced Brakes in Markham-- less than $100 taxes in and delivered. Make sure you lube up the caliper pins.
The pads are pretty new and have lots of material left on them. Pins were polished and lubed when they were installed. Hadn't heard of Max before but will definitely check them out.
Has thanked: 1611 times
Been thanked: 4075 times
Those rotors will clean up but they will eat up the pads badly. If you took a flap disc to them and get them smooth the pads will thank you and wear them in like mirrors.
Been thanked: 504 times
Post by cn90 »
Most of the cars' parking brakes friction material falls off after 10yr/100K miles...
Info in forum.
cn90 wrote: 10 Jun 2022, 20:58 Most of the cars' parking barkes friction material falls off after 10yr/100K miles...
Info in forum.
In our nasty salty climates where brake rotor life is about 5 years max, it makes total sense to refresh the parking brake shoes when doing the rear brakes, especially on a manual transmission car
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I replaced the rear rotors with autozones for less than $40, that was 4 years ago.
br0dy519
Post by br0dy519 »
abscate wrote: 11 Jun 2022, 04:34
Info in forum.
Maybe I should reinstall the parking brake on my wife’s car this year with a new, unseized cable.
04s60 2.4
04xc70 2.5t
