Save my baby
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Re: Save my baby
Post by jonesg »
Mr. Detail wrote: 16 Jul 2022, 12:56 jonesg, could not find any "24 cure" version you spoke of on JB Weld"s webpage.
https://www.jbweld.com/products
marine jb weld, 4 hr set, 24 hr cure. says so right on the package.
https://www.amazon.com/J-B-Weld-8272-Ma ... 43945&th=1
jonesg
Post by jonesg »
Mr. Detail wrote: 16 Jul 2022, 12:37 Holy Cow, you guys are great! Maybe I have some hope after all. I sure don't have any disposable cash like $1,100 right now.
abscate, you are correct in that this mechanic does have one of those cameras (Borescope) you spoke of. This mechanic I have only used in emergencies in the past as his labor rates are high but he is right around the corner. I think he is trying to scare me when he said "I would hate to have your car catch on fire". Great!
br0dy519, which is it? Under the rear bench seat or in the trunk area? Need to confirm. Maybe after viewing "Jonesg" video that will tell me for sure.
jonesg, after following your good instructions, and clean up that area, should I turn on the engine again to see where the actual leak is coming from? Or maybe it will be obvious. You mentioned, "very likely the fuel pump top plate". That doesn't sound like an EVAP hose or a fuel supply line. Just wondering which part(s) I will be JB Welding. That video looks like a lot of stuff to remove. I wished I lived closer to the beautiful state of Maine and I would come up and see you.
DRive the car for 5 minutes, if you smell gas its good indication you will find gas pooled on the pump cover plate.
disconnect battery before starting this procedure, you test the repair by driving after the repair, no more smell.
If you connect the battery with the seat out you're gonna get the SRS warning that you can't turn off without a decent code reader.
the seatbelts are tied into the airbag system, if the circuit is unplugged and you key on, you get the airbag fault code.
Just don't do it and you won't have a problem, the fuel pump is a well known problem that is easily fixed.
I made that mistake and had to spend money for a scanner that could erase the SRS fault. Dealer wanted $150 just to turn it off.
Come on up to maine, we don't do anything but work on the volvo in our retirement, work on the boat, then the motor bicycle, then the volvo again... we'll leave the light on for ya.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
jonesg is retired... Darn, I'm getting old, too...
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Isn’t BOAT an acronym for “Bust Out Another Thousand”?
04s60 2.4
04xc70 2.5t
jonesg
Post by jonesg »
br0dy519 wrote: 16 Jul 2022, 17:22 Isn’t BOAT an acronym for “Bust Out Another Thousand”?
boaters learn to scale down,
aluminum hulls outlive glass and are lighter, cheaper to maintain and need less power.
Old car, old boat, old snowmobile, buy em cheap and fix em up.
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
jonesg, I am 66 yrs. old and thought I was retired this past January but the Mrs. had a different idea. Never easy!
Mr. Detail
jonesg wrote: 16 Jul 2022, 17:06
jonesg, JB weld customer service inquiry gave me this in an email.
"8265S Original"
jonesg
Post by jonesg »
"8265S Original" is not resistant to gasoline.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Here is the portion of my bill on the fuel pump recall from March 2016. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Mr. Detail
June, for what year and model Volvo were you able to receive that free recall?
I searched up yesterday on Volvo's recall site with my VIN number and got nothing on my P2.
