Why do I do jobs on Sundays? I'm doing the passenger side balljoint, wheel bearing, and CV axle today. The CV axle came out so easily I was surprised. Problem is it took three seals/orings with it it looks like. When I look inside the bevel gear, it looks like there are two wells for the two smaller seals. Any idea on these? I'm booting up VIDA now but if someone has a quick answer it would be great. Need the vehicle tomorrow
Passenger Axle Seals - 04 XC70 Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
Hi guys.
wonder how screwed I am
- IMG_4849.JPG (315.07 KiB) Viewed 474 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 1509 times
- Been thanked: 3827 times
I’ll guess someone left an old oring on the axle..
Parts 5 and 8
Parts 5 and 8
- B34038D3-C3D5-43F4-A36F-ED0114E827A1.png (587.03 KiB) Viewed 454 times
- 66F3EA48-127D-4B74-AD57-4287213C53DF.png (378.45 KiB) Viewed 454 times
- br0dy519
Upon closer inspection.. it looks like it may be one seal teared to bits. The one piece is a big circular spring
- C799018C-F2EC-4BCC-BA67-BBCE90B1CD22.jpeg (256.3 KiB) Viewed 448 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- br0dy519
Oh you look to be right abscate. Isn’t this seal very dodgy to replace. I’ll look into it. Thank you.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- br0dy519
Correct P/N : 9143885 , Corteco 1034061 available at 1/4 cost of the Volvo P/N.
abscate's post is at the rear diff. I was replacing the front passenger CV when it happened, so here is the diagram and correct number for the front. This guide helped me : https://www.matthewsvolvosite.com/angle-gear-leak-fix/
VIDA repair instructions show the job is an easy 2 minute fix. Pry old one out with screwdriver. Grease and set new one in. Easy peasy. Car will be back on the road Tuesday as long as I can source the seal locally.
Thanks!
Thanks!
- 9143885.JPG (104.67 KiB) Viewed 420 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 36 Replies
- 18151 Views
Last post by Achilles
- 574 Views
Last post by Mike Langlois
