2005 XC70 Oil Leak?
james166
Year and Model: 2002 s60
Post by james166 »
I have an XC70 (2005, 116K miles) that is using a lot of oil (maybe 1 qt/1000 miles). Looking around the engine, I noticed it was "oily" in an area in the left side of the engine somewhat to the left of the timing belt. I attached a picture here of what it looks like - in the picture the left side is the timing belt cover and the right side is the coolant tank, and looking down between those you can see a lot of oil. Is this normal? I should also mention I did the "rubber glove test" where I put a rubber glove over where the oil fill port and looked to see if I got a negative pressure. The results showed a slight positive pressure, but not enough fill up the glove.
I'm hoping someone has some ideas on what this all means, and what to do about it!
Been thanked: 4065 times
Too much oil, probably a cam seal leak.
Fix the PCV and cam seal together so it doesn't reoccur. A clean PCV will suck the glove in
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 43 times
Been thanked: 6 times
Post by dono »
Old thread but the picture looks exactly like a CAM seal leak (exhaust side) I fixed a few years ago. I used uv dye in the oil to pinpoint it.
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
MDK here, so what happens is that over time the " oil trap ' that is below or under the intake gets clogged up and crankcase is trying to relieve the pressure. This unit is bolted to the engine.. a real ¶%©@ to change. Anyway, it causes pressure build up hence the cam seals both front and rear leak if you were to put an air pressure gauge on the dipstick tube you should see approximately -5lbs. I've seen these replaced and the oil leak goes away, but not always. It may be listed as an oil separator.. same thing.
