P80 headlights Possible to Remove Headlight Reflector, rechroming discussion 8628402 8628403
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
454cid wrote: 07 Nov 2022, 06:32 Yes, They do really light up the road. In fact sometimes it's too bright when I'm driving through construction with lots of reflective barrels/markers everywhere.
Cars approaching you are likely completely blinded.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
850oldschool wrote: 07 Nov 2022, 10:12
Half the newer vehicles on the road now blind you when approaching, anyway.
I remember in the olden days when there were regulations about headlight height and so forth. If they still exist, they must be loosely enforced or ignored. Growing up in NJ, headlight alignment was one of the few things they really checked during your annual drive-thru state vehicle inspection. If your headlights were out of alignment, you failed.
The biggest problem seems to be with tall vehicles like pickups and SUVs, especially if they have been lifted even higher than stock. In many cases, even brand new vehicles are just WAY TOO BRIGHT or are not properly focused or collimated.
Having said all of that, MODERN headlights SUPPOSEDLY can be super bright because they ARE properly collimated and the beam stays on the road. If you put super bright lamps in an old 1960's round headlight with little or nothing really designed to focus or limit the beam, it probably is more of an issue for oncoming drivers.
All U.S. market models.
All running and on the road.
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
They're high beams, they don't get used when there is approaching traffic. I travel on a low traffic divided freeway at 3am.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Eddystone wrote: 07 Nov 2022, 10:34 [even brand new vehicles are just WAY TOO BRIGHT .
When that first started, I assumed they where skipping the burn-in at the factory to save a dime.
Active
Past
RickHaleParker
454cid wrote: 06 Nov 2022, 03:35 The bases are not well formed, and rock up and down in the housing.
Mine came in today and I did a test fit. They don't rock. You might want to check the bulb retaining springs on your car, they may need to be bent back a hair to tighten them up.
Active
Past
RickHaleParker
Looked up the specs for the bulbs on the Oxilam website. The are 4000lm not the 16000lm the Aliexpress vendors are claiming. Standard Halogen H7 is 1350lm. 4000/1350 X 0.8 X 100% = 237% ... down out of the stratosphere to something more practical.
4000lm X 0.8 = 3200lm. Some after market Halogen H7 can go as high as 5000lm.
Active
Past
RickHaleParker
It worked out pretty well. Lights up the road and street signs good but not over done, blinding on coming drivers.
Before
After
Before
After
Day time looks like frosted glass.
The silver was pretty much gone.
Clean up well with a Steel wool soap pad.
Six light coats 1/2 hour between
Remove masking 1/2 hour after last coat.
Active
Past
duckhunt
Year and Model: 1999 V70
Been thanked: 4 times
Post by duckhunt »
Interesting white the white,
I’ve ordered a spray can of the stardust colours go chrome for mine, will post results as they are corroded now and very poor.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
+1 for an objective test!
+10 if you used the same exposure between shots!
+10000000000 if you used the same exposure between shots and checked that ambient nighttime background illumination was generally similar!
+1x10⁹⁹ if you used the same exposure between shots and checked that ambient nighttime background illumination was generally similar using an EV meter and recreated exactly the distance from headlight to house wall!
Whatever the case, outstanding thinking-outside-the-box on this one with white paint. So much more accessible than chrome-ish paint, or chroming itself. I love headlight illumination testing. It brings out the super nerd in me.
Also -> Amazon link
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
duckhunt wrote: 11 Nov 2022, 10:33 Interesting white the white,
I saw some of the products on Youtube. Looked excellent but it's not here in the States :( . A clear coat on the white may provide even more reflection. A little reflection worked wonders as with my S70. Look forward to seeing your results with Stardustcolors!
https://www.stardustcolors.co.uk/chrome ... paint.html
(www.amazon.com/Rust-Oleum-7718830-7718- ... svolvo3-20)
viewtopic.php?p=611673#p611673
