Air Recirculation Not Working
Has thanked: 1609 times
Been thanked: 4064 times
My poor spouse learned to drive stick shift on a 1965 Beetle whose clutch had to be pulled back with string. Awful. That’s a great fix for the damper.
Full ACA award given
C1ph3r
Year and Model: 1999 V70T5
Has thanked: 32 times
Been thanked: 7 times
Post by C1ph3r »
crlande wrote: 09 Nov 2022, 19:34 '94 Volvo started making a clicking noise when that arm and servo broke. I pulled glove box and attached string to recirc flap. Installed glove box, fed string around/over it. Left it hanging inside box. Pull on it when I want recirc flap open or closed!
Now I will sit back and wait for a ACA comment. (Abscate Cheapism Award)!!!
that my friend is brilliant
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
C1ph3r
Post by C1ph3r »
I wanted to update this thread. I was able to get the servo motor out and it was very easy. that one little torx screw was all it took and it slide right out. the motor is bad for sure. after disconnecting the flapper arm and switching the vent button open and closed, the motor stutters bad with nothing attached to it.
got a replacement on the way thanks to Neil for the help with that. fingers crossed it does the job. when it gets here i am going to take apart my original one and see if there is any way to repair it.
just 2 simple tabs towards the front of the car and a single screw facing the rear of the car holds it in
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
