Yet another engine oil question - Shell Rotella?
Has thanked: 2215 times
Been thanked: 1853 times
I recall reading several members who like to us Shell Rotella engine oils. My engine uses 5W-40 oil. One of our local stores regularly advertises Shell Rotella T6 5W-40 engine oil, but it states it is for diesel engines. Can I use that in my gasoline engine or is that a no-no?
https://www.princessauto.com/en/rotella ... 0008633133
In the ad, it just states Heavy Duty engine oil, but their ads including in the store always stat it is for Diesel engines.
Any guidance out there?
Thanks,
Has thanked: 312 times
Been thanked: 818 times
That is the one everyone uses in their gas engines. It's a great oil. Goes for about $25 USD/gallon here, can get the 2.5 gallon for like $60 USD if you shop around. Rotella pretty much always has a farm store rebate program going on, not sure that applies up north.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
The T4 used to be rated for both gas and diesel, and then diesel requirements changed a bit, and Shell dropped the gas certification. I would assume the T6 would be the same.
I decided I didn't care, and it's what is in my 850, since T6 seems to be popular with a lot of people, and it comes in a weight that is appropriate (5w40).
I have read that it's not really the greatest choice for high revving engines, but I believe that's more of a motorcycle engine territory of high revving. It's still popular with the motorcycle crowd, since I guess it will work with wet clutches?
I have not had any oil analysis done on the used oil since I had mixed in something else when I needed to top the engine off, before changing it.
Edit: It's a lot more expensive in Canada! It's only about $25 here in MI.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
When Abscate says everything is better up here in Canada, that maybe for some things, but nothing automotive related! Just looked up the Toyota 4Runner AC evaporator and cheapest OE is $750 CDN!! I can buy OE supplier Denso part for about $180 with shipping and taxes!
I should have ordered the parts when I was down in Scottsdale last week.
Thanks for the info on the oil guys!
MoVolvos
Been thanked: 525 times
Post by MoVolvos »
The T6 5W-40 is an excellent oil. Not sure if I posted these pictures but Rotella wasn't available for awhile so I stocked up when there was a sale and experimented with other oils. The gas rating went away but someone posted a response in BTOG from Rotella stating the formulation has not changed.
I believe they drop the gas rating to make way for the newish now Rotella Gas Truck motor oil in order to create a broader market and market share with the newest API ratings. Shell already knows there is huge following from bikers and gas engine owners who will continue to use it. With the Gas Truck they have new customers who otherwise wouldn't use a diesel oil in their vehicles. Didn't care for the Gas Truck oil after trying it but am back to using the T6 5W40 when the others run out.
Purchase a jug of the T6 already but didn't bring it to my folks when I changed the oil on the C30 Sunday. Went ahead and put Swepco and Liqui in combination for the oil change.
https://www.walmart.com/ip/Shell-Rotell ... thena=true
Has thanked: 1613 times
Been thanked: 4077 times
You can buy liquid Moly from FCP in CT and return it on warranty after your OCI, ISYN.
454cid
Post by 454cid »
I think the Gas Truck Rotella got discontinued. It was quite expensive here, even when on clearance. I did get a 5-quart jug, but it's still sitting on my oil shelf.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
...and remember never to mix Shell products and Mobil products
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Your operator’s manual should state what the manufacturer says is best for your engine.
EDIT: isn’t Shell Rotella for heavy duty Diesel machines?
BMW 540i 2002
S70 Base 2000
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I think the reason folks like the Rotella is that it had more ZDDP ( Zinc ) than most other oils, which is good for any flat tappet engine to help prevent wear of the cam, lifters etc.
1999 V70 GLT
