Hi every one, I am trying to positively identify if my AUTRALIAN DELIVERED 1994 850 sedan is 10 valve or 20 valve.
I can see no identifying numbers on the motor or I.D plates.
The owners manual in the glove box lists 5 motors it could be and naturally these include both 10 and 20 valve motors which is unhelpful
I have read a bit on this forum that Australian 850s (apart from the rare T and T5 ) were delivered as 10 valve.
On the spark plug cover is written DOHC,
Other than that Im stumped, where is the identifying number located on the motor? ( if at all )
Many thanks in advance, Buster
Is my 1994 850 10valve or 20 valve ?
- Has thanked: 1613 times
- Been thanked: 4078 times
It’s stamped into the block on the right side of car near firewall. You usually have to clean it to read it. It’s holes punched into aluminum in shapes of numbers.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
You don't have a sticker on the broad side of the timing belt cover?buster850 wrote: 07 Jan 2023, 20:58 Hi every one, I am trying to positively identify if my AUTRALIAN DELIVERED 1994 850 sedan is 10 valve or 20 valve.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
buster850
- Year and Model: 1994 850 GLE
- Has thanked: 15 times
- Been thanked: 8 times
Hi , thank you for the help. I took a look in that area but I can not get a look at the rear of the block on the right hand side. I can only see the rear edge of the head, everything below that is obscured by the inability to get a good look down behind to the block, also the exhaust shroud shields the view of that area of the block. On the plus side I did find it on a sticker on the timing belt cover 85252S which I guess denotes 10 valve.thanks for your input tho. Would the motor have to be out to see the stamped area of the rear of the block or are you saying I can see it by standing against the fender and looking in ?abscate wrote: 07 Jan 2023, 21:05 It’s stamped into the block on the right side of car near firewall. You usually have to clean it to read it. It’s holes punched into aluminum in shapes of numbers.
Cheers Buster
buster850
Thanks very much , I found it is on the timing cover 85252S which must denote the 10 valve. Cheers Buster454cid wrote: 07 Jan 2023, 23:00You don't have a sticker on the broad side of the timing belt cover?buster850 wrote: 07 Jan 2023, 20:58 Hi every one, I am trying to positively identify if my AUTRALIAN DELIVERED 1994 850 sedan is 10 valve or 20 valve.
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
It's not an 8, it's a B. The motor code should be B5252S (Gasoline 5 Cylinder 2.5 Liter 2 Valves per cylinder. Forgot what S is)
1996 855 R,
2010 V70 D5,
2010 V70 D5,
S is naturally aspirated. T is for turbo
S stands for Sadd which is Swedish for normal air, loosely translated
The engine codes consist of a series of letters and digits:
1st: Fuel type (B/D/GB) B = Bensin (Petrol), D = Diesel, GB[47][nb 3] = Gas & Bensin
2nd: Number of cylinders (4/5/6)
3rd & 4th: Approximate displacement in deciliters, may be rounded up or down. (23 ~= 2.3 L)
5th: Valves per cylinder (2/4)
6th: Induction method (S/T/F/G/GS/FS/FT/SG) S = sadd (naturally aspirated), T = turbocharged, F = fuel injection with catalytic converter, G[48] = leaded fuel compatible, GS[49] = leaded fuel compatible, naturally aspirated, FS = fuel injected standard (naturally aspirated) with catalytic converter, FT = fuel injected, turbocharged with catalytic converter, SG[50] = standard (naturally aspirated) compatible with alternative fuels (LPG / CNG)
7th: Engine generation or engine variant (2/3/4/5/6/7/8/9/10/11)
Engine codes are not necessarily unique to a specific engine as power levels can vary depending on market, manufacturer and model.
- 10 Replies
- 3606 Views
Last post by southofmotown
- 745 Views
- 2274 Views
Last post by pgill
- 3959 Views
Last post by dono
- 718 Views
Last post by shaker_chi
