No. On the intake, just past the throttle body. It is usually hidden under the cover over the throttle cable attachment.
1998v70 Car Will Not Start AGAIN
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I wonder if it would make any sense to pull the connector off the ECT sensor and plug in a potentiometer or resistor in its place for testing.
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
One screw clamp at the throttle body. It is also easier to remove the cover (one screw over the vacuum tree) to get at the accordion screw clamp. You would be amazed at how much gunk is on the butterfly valve in the throttle body anyway, once you get clamp and tube off.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Ohok, so i guess you have to take that one big hose clamp off.
- MrAl
Hi,crlande wrote: 07 Jan 2023, 11:51 One screw clamp at the throttle body. It is also easier to remove the cover (one screw over the vacuum tree) to get at the accordion screw clamp. You would be amazed at how much gunk is on the butterfly valve in the throttle body anyway, once you get clamp and tube off.
What is a vacuum tree?
454cid
- Has thanked: 151 times
- Been thanked: 139 times
The vacuum tree is the plastic piece that fits in the top of the intake manifold and has multiple vacuum ports. It's on the right on my 96.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Chuck W
You can see it in the middle of the right edge of this picture. Right were that white vacuum line comes into the picture. You need to remove the cover that's over all of this mess to get at it.
- MrAl
Ok thanks i'll look for it. Already got that little cover off.Chuck W wrote: 08 Jan 2023, 06:20 You can see it in the middle of the right edge of this picture. Right were that white vacuum line comes into the picture. You need to remove the cover that's over all of this mess to get at it.
Nice pic BTW.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Yeah, that will do it, it'll still get sucked in.MrAl wrote: 07 Jan 2023, 09:41Ok i guess that ECT will have to be checked again at some point. Just had it replaced about a year ago.Chuck W wrote: 07 Jan 2023, 06:40 There's also a vacuum tree on the intake you could shoot some in, without having to mess with opening the throttle.
I'm also going to suggest (re)checking the ECT sensor and connector. I had a bad one that really gave me fits when it was cold. It ran marginally bad when it was cool, but when it got cold, it wouldn't start, and was unhappy with any attempts to make it start.
You mean shoot some in where the air filter is?
2023 Lexus RZ450e -66k
- MrAl
Hi,wizechatmgr wrote: 09 Jan 2023, 20:27Yeah, that will do it, it'll still get sucked in.MrAl wrote: 07 Jan 2023, 09:41Ok i guess that ECT will have to be checked again at some point. Just had it replaced about a year ago.Chuck W wrote: 07 Jan 2023, 06:40 There's also a vacuum tree on the intake you could shoot some in, without having to mess with opening the throttle.
You mean in the air filter?
- 118 Replies
- 9109 Views
Last post by BlackBart
- 1407 Views
- 13 Replies
- 12620 Views
Last post by SVO LOU
- 37 Replies
- 8807 Views
Last post by songzunhuang
- 809 Views
Last post by T64me
