1998v70 Car Will Not Start AGAIN
Has thanked: 1609 times
Been thanked: 4065 times
Best is to undo the snorkel, big hose clamp, open the throttle by hand, then a 3 second squirt into the throttle body. Close throttle body,, reinstall snorkel, then test cranking, promptly. You don’t have to run, but don’t wait 5 minutes.
You can tighten snorkel after crank test
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 09 Jan 2023, 23:36 Best is to undo the snorkel, big hose clamp, open the throttle by hand, then a 3 second squirt into the throttle body. Close throttle body,, reinstall snorkel, then test cranking, promptly. You don’t have to run, but don’t wait 5 minutes.
Hello,
Oh ok thanks, i'll give it a shot. I also ended up with another question ill ask in another thread.
Look inside the snorkel to see of you need a throttle body cleaning too. It needs this every 50k
You need one piece new gasket for that job…it should look like this…..
https://www.fcpeuro.com/products/volvo- ... oe#fitment
I can stick one in my weekly FCP order and mail to you if needed.
Cost $3.79+ 0.60 shipping + $15 eco-friendly packaging + shop,supplies + VAT + Wall Street bonus tax
MrAl
Post by MrAl »
abscate wrote: 11 Jan 2023, 02:41 Look inside the snorkel to see of you need a throttle body cleaning too. It needs this every 50k
Hi,
Ok thanks i'll check that out soon.
I was also wondering, does that metal accordion hose need any gasket?
I'm wondering what holds it into the other hose in the back of the engine.
Has thanked: 2199 times
Been thanked: 1852 times
No clamps on either end if I recall. On the manifold side it should have a sleeve it goes over, and same on the air-box end.
https://www.ebay.com/itm/185019791507Here is a link to Ebay with a picture of a NA exhaust manifold heat shield with the sleeve over which the silver pipe fits. It is a snug fit on this.
This is the other end at the air box. This picture is just of the air flap portion removed from the main filter box section. The arrow marked ' Hot air' is where the pipe fits.
MrAl
Post by MrAl »
scot850 wrote: 13 Jan 2023, 15:03 No clamps on either end if I recall. On the manifold side it should have a sleeve it goes over, and same on the air-box end.
Hi,
Don't see the airbox end, but you mean i can disconnect at the airbox instead?
This picture is the airbox on it's side. The connector is the tube currently facing to the ground. It is hard to see from above. The plastic has ridges in it on the airbox end to hold it on.
https://www.ebay.com/itm/203581409055
MrAl
Post by MrAl »
scot850 wrote: 14 Jan 2023, 14:51 This picture is the airbox on it's side. The connector is the tube currently facing to the ground. It is hard to see from above. The plastic has ridges in it on the airbox end to hold it on.
Hi Neil,
Oh that's a nice picture thanks.
I rotated the pic right side up and labeled the ports.
Is this new drawing correct?
Also, i take it the box is held down with that one clip as labeled in the pic also?
Thanks.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I think there's 3 places where it's held down. It's a rubber plug type deally. You just have to pull and the box will come out after everything else is removed.
The top side of the rubber thing fits in the box, and the bottom fits in a plastic tray that's bolted to the car. I guess they're so the box can move a bit yet is still restrained enough to stay in place. The first time I removed the air box on my 850 I thought the rubber pieces were in horrible shape, but they were just dirty. I scrubbed them up in the sink with an old tooth brush and cleaner, and I realized they were fine.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Correct labeling. There are 2 pins on the far side we are looking at that push into rubber bushes on the inner fender. There are 2? feet at this end and you can see one of them. They snap onto 2 splayed plastic barbs.
