New bougicord wires not correct? And oil filler cap recommendation
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
I bought a set of Bougicord spark plug wires, part number 9135700 for a 98 v70, which is supposed to fit these 20 valve cars, yet all 5 of the leads to the spark plug don't have enough reach to make good contact with the distributor. For some reason, the coil to distributor wire isn't as recessed in the rubber boot and clicks onto the posts of the coil and distributor and stays on snugly.
Top is one of the new bougicord spark plug leads, middle is the bougicord distributor to coil wire, and on the bottom is the old wire of unknown brand.
The plastic boot that fits over the spark plug is also longer too, and caused the rubber boot to be sticking halfway out of the head instead of flush like with my other cars. Top is the bougicord, bottom is the old wire.
Here's the box I got from Eeuroparts.
Looking on most parts websites for the same part number, the bougicords have gray plastic boots, and come with clips to keep the wires together, while pelican parts shows the wires I received.
Has anyone had this problem or know why these wires would be like this?
Side note: the wires were bought to replace the known good wires I took off the v70 to install on the 97 GLT(which was needed urgently by a family member) that developed rough starts and intermittent misfires and codes for misfires on a cylinders. The leads on the 97 had gone bad from a large amount of oil seeping down the oil filler neck and filling up the spark plug cavities.
PCV job had been done less than 50k miles ago, no inflation during the glove test, tried replacing the oil cap gasket many times. Finally gave in and bought an OEM Volvo oil cap from FCP, which despite having an ad for Castrol on it, fixed the problem and the top of the engine has been bone dry.
TLDR: Aftermarket oil filler caps are garbage, Volvo OEM cap fixed the problem.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
eeuroparts bites since they got bought out. FCP Euro, the linked one on this site, is the way to go.
Has thanked: 2200 times
Been thanked: 1852 times
There have been at least one or two others that have had this issue in the last 6 months. The 10V and 20V are different.
As for oil filler cap. The seal needs to be replaced every 2-3 years if you want it to stay leak free. The seal shrinks and goes hard, then it leaks. Cheap aftermarket seal rings. No need to replace the whole cap, but as you have done should be good for a while!
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
The white and gray boot is how they should look. Send them back!
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
crlande wrote: 12 Apr 2023, 14:43 eeuroparts bites since they got bought out.
They got bought by a mega auto parts online organization. I kept up some communication with one of them, a VP level person (maybe? I forget...) or somesuch, after the buy-out. I got the feeling they were not all-in on understanding the nuances of Volvo parts.
Also -> Amazon link
jsrnsis
Post by jsrnsis »
scot850 wrote: 12 Apr 2023, 17:27
Problem might have been cheap seal rings that hardened within weeks, but the filler cap that was on the car was actually loose enough that you could move it around on the filler neck.
crlande wrote: 12 Apr 2023, 14:43 eeuroparts bites since they got bought out. FCP Euro, the linked one on this site, is the way to go.
Unfortunately FCP is out of stock for these bougicord leads that are recommended here and had them listed as discontinued, which seems to be the case with more and more parts lately.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I just I checked FCP as well. Seems STI is the only brand available currently. I can't believe something as spark plug wires are being discontinued. Sounds like a coil on plug conversion might be in the future for me. What does fcp do with warranty parts that are NLA?
IPD lists the Bougicord plug leads for a 1994 turbo. Did not check for a NA but I believe they are the same.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
It looks like what happened to me. I bought through FCP, and was shipped 10-valve parts. I think Bougicord mislabeled some boxes. FCP replaced them, on their dime, and did not have me ship the wrong wires back. The second set was correct, and is currently on the car.
I shipped the wrong wires to a board member in Australia, since he has a 10-valve. Unfortunately, they ended up being wrong for his car, too. Apparently for a short time Volvo used a different connector on the distributor cap and he had the other design.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
jsrnsis
Post by jsrnsis »
454cid wrote: 13 Apr 2023, 10:33 It looks like what happened to me. I bought through FCP, and was shipped 10-valve parts. I think Bougicord mislabeled some boxes. FCP replaced them, on their dime, and did not have me ship the wrong wires back. The second set was correct, and is currently on the car.
Eeuroparts made me send the parts back, but kept saying they only take back "new and uninstalled" parts. I don't know how I would have figured out they were wrong unless I tried to install them. Just something to keep in mind if you have to order from them. Or else I would have offered them up to anyone here that needed them.
scot850 wrote: 13 Apr 2023, 07:53 IPD lists the Bougicord plug leads for a 1994 turbo. Did not check for a NA but I believe they are the same.
I called IPD and they said they haven't had any returns of their bougicord leads in a couple years besides one person who got two of the same length wires in a set, so they must not have gotten any 10 valve parts mixed in.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
