Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Took all of the bolts too. I was thinking that I might buy two new ones for the main subframe attachment because those heads took some hits when the forklift picked up the car. I obviously got them off, but considering the torque it seems they are set at, I'd feel better with a couple of new ones.
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
scot850 wrote: 15 Apr 2023, 19:09 The bolts I pulled are the same as the others I have from other cars in my stash. Not 100% convinced of the 2 different bolt lengths. I'm probably wrong!
Sveedy wrote: 15 Apr 2023, 21:05 Took all of the bolts too. I was thinking that I might buy two new ones for the main subframe attachment because those heads took some hits when the forklift picked up the car. I obviously got them off, but considering the torque it seems they are set at, I'd feel better with a couple of new ones.
Yeah, the big bolts are a little longer, and the 3 others on the plate are a good 15mm or so longer, seeing as the bracket there is as thick as the brace tubing. The 4 bolts on the other plate are the same as the non-vert cars.
You will need to add threaded inserts, unless your car has a vert subframe under it already for some reason. (if you have 2-bolt control arms, you don't have a vert subframe)
Has thanked: 1506 times
Been thanked: 3822 times
I think Volvo says new on the long ones into the snout whenever the subframe is removed. You don’t have to listen to Mother always, but an inspection protocol if you reuse would be smart
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
For that front brace, I would recommend rivet style nut inserts like these https://www.harborfreight.com/10-in-pro ... 58078.html
abscate wrote: 16 Apr 2023, 00:18
Inspect, clean threads, blue loctite, reinstall. Should be fine! Probably... :wink:
Has thanked: 1853 times
Been thanked: 1714 times
You get different riv-nuts, aluminum, steel and stainless. I would go with the regular steel ones. They are more flexible where stainless are too rigid.
Those are exactly what I would have used, but I still have to check if they rear mounts are where the AWD prop-shaft bearing mounts to.
Tough call. I don’t like Loctite as it means dry threads , and in the rust belt that’s death.
I nickel antiseize them, torque to spec, then punch mark them.
Inspect marks daily for a week, weekly fir a month, then monthly for six months.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
abscate wrote: 16 Apr 2023, 16:25 Tough call. I don’t like Loctite as it means dry threads , and in the rust belt that’s death.
Have you experienced corrosion using Loctite? It's my understanding that it should also keep moisture out. I don't usually use it on the undercarriage, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
bmdubya1198
Interesting note on the loctite. I could see that potentially being a problem. I've had the privilege of replacing rear wheel bearings on a BMW that seems to have been up north. It's a 2015, and the effort I have to put into removing those rear axles was unbelievable. I absolutely destroyed one of the stubs, and the other one survived after some more careful heating and half a can of PB blaster. Man, I'm spoiled living in the south.
That said, the next day, I smoothly removed two axles without a single hammer impact from a 2005 BMW X5. Southern car... go figure!
xyna
Year and Model: Volvo 740 1990
Post by xyna »
CIK7 wrote: 05 Mar 2023, 12:13
xyna wrote: 01 Mar 2023, 09:17 Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
Has your car been in an accident? I suppose plastic could get old, but i think the window regulator is metal, isnt it? I didnt think that could crack.
Took a while for me to check this forum again, but I literally just closed the door. Probably used too much force doing so. The internals of the motor in the window regulator is metal, but on the outside it is just plastic.
Today I removed the wooden trim of my S70 that I am parting out, along with other parts of the interior and some AC piping with my friend who also has a S70 and needed some parts and wanted the wooden trim. Also worked on my slightly rusty 740 wagon, hoping to get it inspected for the summer!
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 329 times
Been thanked: 87 times
Post by CIK7 »
Yesterday, I took the Rotten Tomato to Moore to look at a car. Left it running while looking at that car, while getting food from jimmy johns and chikfila, while getting groceries from aldi, and while in walmart. The ac did not run out or get weak, the engine stayed cool, and it performed very well. I even had a last minute detour to home depot in Ada to get 10 bags of mulch. Fat dog Spencer comfortably rested in 2nd row with the 60% split cushion folded up and blanket down. My girl Rose curled up next to me in the front seat awake and anxious. 2 dogs, 10 bags of mulch, and groceries. A semi-productive trip in a schmancy 5 speed; that was fun. I didn't like the laid-back careless attitude of the salesman toward maintenance of the car. But a fun trip nonetheless.
Im not kidding, i stress out because Im concerned it might overheat like the white one did, even though that was fan related, or like the more likely chance the 960 has in hot climates. But it worked good yesterday! Does anyone here have an elevated stress level about their Volvo failing in some way? Stress they dont have with their non-Volvo cars?
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
