06 V70 won't come out of park Topic is solved
SVO LOU
Year and Model: 04 XC70, 06 V70
Has thanked: 41 times
Been thanked: 5 times
Post by SVO LOU »
Hey All,
I have an 06 V70 that won't come out of park sometimes. It started acting up during the colder weather and I thought it may have been a possible sugary drink spill (no evidence but I haven't owned it since new), once the car warmed up it would come out of Park and work fine so I sprayed below the shifter with foaming glass cleaner.
All worked well until a couple of weeks ago but now it's worse, no amount of warming up helps, even if it's 70 degrees out. I can hit the brake pedal and feel a solenoid "clunk" in the shifter and see a black plastic piece underneath the shifter bezel move and return when hitting the brake pedal but it still won't release the shifter out of park.
In the colder weather I replaced the brake light switch with a new one but it didn't help.
Any ideas or suggestions would be greatly appreciated.
01, 02, 04 XC70, 06 V70
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
There's another cable, attached to ignition cylinder. Remove it and see if that helped. Or maybe it came off, I had that happened to me once.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
SVO LOU wrote: 02 May 2023, 20:03 Hey All,
mine does the same at 20 below zero, I let it warm up,
I suspect the lockout solenoid at the shifter.
motormikeyman
Year and Model: 2004 XC70 AWD
Been thanked: 8 times
Post by motormikeyman »
You will need to replace your shifter knob- very easy 5 minute job. Something breaks inside and it will not actuate the release rod to get it out of park. At least that's what it was in my case.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
SVO LOU
Post by SVO LOU »
Appreciate the tips everyone.
When I was finally able to remove the key I took off the switch (the part on the left side of the lock cylinder) and used a wax-based bike chain lube to lubricate the interface between the two and opened the shutter of the lock cylinder and lubed that also. The cylinder then turned extremely smooth but the shifter would still hang up sometimes so it was actually two problems.
I then removed the shifter bezel and lubed around the left-side of the shifter (where you can see the white plastic piece moving when pressing on the brake).
So far, so good. Thanks all.
