If the 3rd brake light turns on with the brake pedal, then your brake switch is good. Could you tell us if there was anything that led to the brake lights not working? I ask in case the issue happens again.MARCUSBUTZIN wrote: ↑16 Apr 2022, 18:37 2011 XC90 I have third brake light (upper center ) working but not either side. Is the relay on the left corner interior? Does anyone know if there is a brake light relay under the hood? Advise please!
Did you recently change the battery?
Did you notice any water in the rear areas?
Were bulbs recently changed or did you have LED bulbs installed?
Any rust in the bulb sockets?
Is it only brake lights or are the parking lights (tail lights), license plate light, and/or reverse lights also out?
Bookmark the site linked below so you can find information next time. It's basically the online VIDA for info.
As mentioned, check Fuse #30 for the brake lights. Here is more detail & diagram information: https://workshop-manuals.com/volvo/xc90 ... age_16601/
If you also have tail lights that are out, then it's Fuse #2: https://workshop-manuals.com/volvo/xc90 ... age_16596/
Good luck.
