The original stereo/cassette in my car works fine. However, I am considering replacing it with a double din unit for things like Apple Car play, for GPS via phone, streaming music etc.
I was told by someone my car can only accept Kenwood systems. Is this true??
Upgrade stero head unit? 850GLT
- Has thanked: 2197 times
- Been thanked: 1850 times
Try checking with Crutchfield. Their website and support is usually very good. I will try to find out what my brother fitted to his 97 850 for the same connectivity reasons.
The original units were made by Alpine and possibly one other maker.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Absolutely not.viper69 wrote: 07 May 2023, 19:36 I was told by someone my car can only accept Kenwood systems. Is this true??
You can drop pretty much any
single or double DIN in that dash.
If you go single, there are pockets
available to fill the extra DIN space.
There are numerous write-ups on
this and other Volvo forums.
Cliff Notes:
Get a wiring harness adapter to
make it a plug and play operation.
Matching colors between the adapter
and any decent HU make wiring a breeze.
Then you'll be able to plug right into the
Volvo's radio plugs with zero issues.
Be prepared to remove the plastic "rails"
on either side of the cavity the radio slides
into. If you pop the existing unit out, you'll see.
You'll probably also be cutting a few holes into
the sides to make anchor points for the HU cage.
There may also be some fiddling with a dash
trim ring for the new HU. They're all different.
Your mileage may vary...
Wagon or sedan, be sure that you connect
the power antenna control wire (blue) from
the wiring harness adapter to the matching
control output from the new HU.
On the sedan, it physically raises the antenna.
On the wagon, it powers up the hidden window
antenna's amplifier. No amp, no radio...
You'll also have a leftover antenna plug in the car.
P80's have two - A regular size and a mini. You
won't be using the mini antenna connector with
the replacement HU.
Happy Motoring!
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Interesting info- yep I remember it being Alpine. I put a Alpine CD changer in the trunk many years ago.
Well this is good news. I’ll call Crutch, I found their site confusing with all the subdivisions of HUs.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Last time i visited that site because of front door speakers for 850...site said 160mm diameter while actually it is 130mm...front and rear door.viper69 wrote: 08 May 2023, 06:07 ...I’ll call Crutch, I found their site confusing with all the subdivisions of HUs.
Totally useless site for me.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I had issues a few years ago and found them very helpful. Time moves on and maybe the good employees as well?
- 16 Replies
- 13672 Views
Last post by darylrobert
- 398 Views
Last post by 800artfreed
- 549 Views
Last post by misha
- 1082 Views
Last post by matt122s
- 2064 Views
