Meyle HD not so HD
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Meyle HD not so HD
Post by WhatAmIDoing »
I was replacing the blown out sway bar end links on my V70. Unfortunately while torquing the new Meyle "HD" links down with the ratchet before the torque wrench, the stud snapped off. Could tell something didn't feel right. Glad it wasn't while I was on my way to the alignment.
Meyle Heavy Doody
Meyle Heavy Doody
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Nothing would happen...except a loud bang it would make when it would fall of the strut or sway bar.
Car would be driveable.
Alignment after sway bar link replacement?!
Unless you touched the tie rod adjusting bolts...no alignment needed.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1847 times
Been thanked: 1710 times
It is weird, in your picture it looks like the threads are a different size? Probably just an optical allusion. How tight did you get it? They don't have a huge torque on them, can't recall it off the top of my head.
If you have not done any other work on your front suspension, and only replaced the end links, then you should not need an alignment as Misha says. If you replaced tie rods then yes.
WhatAmIDoing
Sorry for clarification, I was also doing tie rods at the same time. I saw varying torque specs from 40 to 60 ft-lbs. I don't think it even made it close to 35.
Torque is 50NM or 37 ft/lb for end links.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Is it soft like aluminium or.. was material too much hardened so it became brittle and broke?
magna224
Year and Model: 850 T5's
Been thanked: 3 times
Post by magna224 »
I had a shop put a meyle end link in my volvo a long time ago and it bent on the way home driving on the dirt roads lol.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
foggydogg
Has thanked: 83 times
Post by foggydogg »
WhatAmIDoing wrote: 24 May 2023, 17:53 Sorry for clarification, I was also doing tie rods at the same time. I saw varying torque specs from 40 to 60 ft-lbs. I don't think it even made it close to 35.
Don't get thrown off by the Euro-centric crowd; those are NM numbers. There's no way that little 10mm shaft can stand 60 ft/lbs.
30-35 ft/lbs is the number I've seen elsewhere here, and goes without saying there should be no side load on the stud during installation - get things lined up before tightening the nut. The stud needs to be in tension before it gets loaded.
There is a torque chart floating around the 'net - and repeated on MVS - that has several errors along those lines.
If you check my note above, I have posted the correct values in Ft/lb and Nm.
