Bumper and trim restore? What do I use?
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Kiwi shoe polish, no way! Have you used it long enough to see how it’s lasting in the sun?
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
Yes. Been using it for years. Way cheaper than the alternatives, and it works. Try it on a piece of door side molding.BlackBart wrote: 09 Jun 2023, 09:31 Kiwi shoe polish, no way! Have you used it long enough to see how it’s lasting in the sun?
Car was garaged for 15 years and then moved outside when I got a newer Lexus GS350. The plastic trim started to get dry once outside. I use to use Armor-All to keep it shiny. The black polish will dull over time, but with the foam applicator, it can be easily reapplied. Just try to keep it off of the paint, or have a microfiber to get the excess.
Make sure you get the liquid shoe polish, not the paste...and shake the bottle prior to applying.
- Has thanked: 1611 times
- Been thanked: 4072 times
It also marks people who walk by your car too closely to remind them not to scratch it.93SCMax wrote: 09 Jun 2023, 05:37 I use Kiwi black (Noir) liquid shoe polish with the foam applicator. It's a Johnson and Johnson product. Easy to apply and wipe off any excess. If your plastic trim is dried out, it will soak up a lot of polish, but is a good protectant. I think it looks good, and not very expensive.
Try it on your side (door) trim 1st and see what you think.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Krylon Fusion (plastic compatible)in Satin on front bumper, wish I would have done flat as it still has more shine than I’d like. Still debating whether to switch to matte on the rest.deano1 wrote: 07 Jun 2023, 04:34 Hey there
I've tried a lot of those plastic restore products before I got fed up because they just don't last.
Frustrated from failed attempts I painted them with flat black rust paint.
Truly the best results so far and super easy to pop out the bumper inserts and give a quick spray hang by one of the tabs in the sun to dry then re insert.
Cheap and effective solution.
Trim still looks like new 1 year later.
Cheers
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
Update on another solution for faded plastics. For winter riding this year I’m coating my motorcycles with ACF-50. ACF is ‘anti-corrosion formula’ originally developed for the aircraft industry.
Anyway, I was so impressed with the results on brightening/darkening the black plastic on my old BMW I thought I’d try it on my windshield sill tray on the S60 that was a quite faded gray. Wow what a result. I’m a couple weeks after doing my bike but still holding up, hopefully this will be my go-to. Not cheap but the best product I’ve found before resorting to paint.
It is an oil based product so after a soak need to wipe to attract less dust. They say on metals it provides up to 12 months of rust protection (if not soaped off, have to rinse only w/ cold water for salt protection. Hopefully it’ll moisturize the plastics a good long while.
Some photos after 24hrs, arrow indicating parts I missed: After first ride after applying ACF-50:
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
We used Avalon King Ceramic Coating on our car, windshield, all glass, headlights and trim. It has held up for I believe a couple of years now. Was looking for a particular video where a guy used it on his trunk's trim but saw this product instead.
Several weeks ago, in a hurry I used a tire shine on the trim and it worked but super greasy. I've also tried transmission fluid years ago and basically anything greasy or oily will coat the trim temporarily making it look good.
Solution Finish
(www.amazon.com/s?k=Solution+Finish+Blac ... _sb_noss_1)
Solution Finish
- Krons
The coating of a ceramic would be good. The ACF-50 is supposed to creep into metals to prevent corrosion so I’m curious to see if its ability to add some oils back to the plastics will hold up. Will update with how it holds up.MoVolvos wrote: 24 Nov 2023, 10:15 Several weeks ago, in a hurry I used a tire shine on the trim and it worked but super greasy. I've also tried transmission fluid years ago and basically anything greasy or oily will coat the trim temporarily making it look good.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- famfeld
- Year and Model: 04 xc70
- Has thanked: 9 times
- Been thanked: 6 times
I pained my plastic bumper door and skirt plastic with truck bed coating after scuffing on my 04 xc70. Looks amazing. Before that i would put tranny fluid on a clean rag every so ofter to recondition. I really love the black painted textured look I got with the bed coating.
Pm me and ill send pics
- MoVolvos
Ceramic I feel is the best as it's not oily. Anything that is oily will be uneven after a washed or two with any detergent or chemicals. The ceramic restores the color and seals the surface. It's almost like a clear coat of lacquer paint except it's the properties of ceramic. When my Son removed his university parking sticker you can feel a slight edge around where the sticker use to beKrons wrote: 24 Nov 2023, 10:59The coating of a ceramic would be good. The ACF-50 is supposed to creep into metals to prevent corrosion so I’m curious to see if its ability to add some oils back to the plastics will hold up. Will update with how it holds up.MoVolvos wrote: 24 Nov 2023, 10:15 Several weeks ago, in a hurry I used a tire shine on the trim and it worked but super greasy. I've also tried transmission fluid years ago and basically anything greasy or oily will coat the trim temporarily making it look good.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I bought a 12oz bottle of that trim restoration and will have it Monday. I'll try it out and put some pictures up next week. The videos I've watched seem pretty convincing. I've been looking for a solution to this for awhile now but didn't want to paint the plastic. Stay tuned!
2003 XC 70 (sold)
- 1474 Views
Last post by RickHaleParker
- 17 Replies
- 4883 Views
Last post by Sveedy
- 348 Views
Last post by MoVolvos
- 1373 Views
Last post by mike:
- 632 Views
Last post by IlikemyXC70
