I'll be pulling it again in a few days. Might start with peripheral removal today, but actual head removal will happen tomorrow or the day after, depending.
The cam cover was and is still fine, in fact I also wondered how the head can crack BEFORE the cam cover which is definitely thinner. But one little detail is, that while I was using the cam cover compressor, the right side of the cover(4th and 5th cylinder) had fully sealed before the left side near the gears, and I made sure to do each turn equally on both sides.
The head was torqued using a torque wrench following the the little pamphlet supplied with the head gasket, which said 30nm first on all bolts, then 60 then 120 degrees which is what I did following the bolt pattern on the instructions.
Probably doing a first start tomorrow. Hope it works. (Cracked cylinder head) Topic is solved
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
It's getting very unpredictable what happened. The exhaust ports all have oil in them the antifreeze got mixed with oil.
Still either cracked head or warped block(yes they do warp in Europe because the cars are often run on LPG/CNG and in very hot climates, like 40c+ ambient temps)
- Has thanked: 1611 times
- Been thanked: 4075 times
That’s not right. It’s a three stage 20 Nm 60 Nm then 130 degree angle, working ftom inside out is important too, both loosening and tighteningThe head was torqued using a torque wrench following the the little pamphlet supplied with the head gasket, which said 30nm first on all bolts, then 60 then 120 degrees which is what I did following the bolt pattern on the instructions.
Jimmy57 recommends two uses from cylinder head bolts, then use new. Rein bolts are fine in my experience, $2-3 each
dikidera
What isn't right is my fuzzy memory as I threw the pamphlet away, but it is as you said, 20nm first, from inside out, then 60 then 120 degrees. My memory is out of whack these past few days due to the stress.abscate wrote: 22 Jun 2023, 04:18That’s not right. It’s a three stage 20 Nm 60 Nm then 130 degree angle, working ftom inside out is important too, both loosening and tighteningThe head was torqued using a torque wrench following the the little pamphlet supplied with the head gasket, which said 30nm first on all bolts, then 60 then 120 degrees which is what I did following the bolt pattern on the instructions.
Once I get the head tested for cracks I will know what will follow. If the head had cracked, I wouldn't get oil in ALL the exhaust ports and in coolant. The only other culprit is a warped block which is what I was most afraid of. Because at that point I would rather buy a used engine and replace it one go, unfortunately I have neither the hoist nor the space to do it, I mean, I have to take out the automatic gearbox first. So it would then appear I have wasted my time and money to do all the procedures I did thus far.
I really doubt the block is warped. There are only two oil passages in the top cylinder head to feed the valve train and cam bearings so the crack should be easy to find. I’ve got two reworked cylinder heads sitting in my shop right now, waiting for my Devils tinsnips
dikidera
Well, a shop said it's unlikely the head is cracked and refused to test it, cause it would be a money waste they said. They also said the cam cover would crack first.
Anyway, I had given the head to a friend, who...has nicked the head cam bearings and I am unsure how problematic that will be. Just my luck really.
As for the original problem...I think I found the problem. But...now I need a new head gasket, new bolts, new oil, new coolant. And a way to fix the cam bearing on the head.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Make a picture and post here.dikidera wrote: 23 Jun 2023, 03:19 As for the original problem...I think I found the problem. But...now I need a new head gasket, new bolts, new oil, new coolant. And a way to fix the cam bearing on the head.
vtl
In case you don't know it, the head bolts must be oiled (no dripping oil though) prior installation or you loose about 1/3 of torque. Even better use a special torque lube.
Wait - what engine family are we on here? I thought P2s ran in machine matched cam surfaces for both axial and thrust play - no bearings at all.Anyway, I had given the head to a friend, who...has nicked the head cam bearings
- 2209 Views
Last post by precopster
- 10 Replies
- 640 Views
Last post by lukask
- 1339 Views
Last post by BEJinFbk
- 2345 Views
- 38 Replies
- 16168 Views
