Is there a way to disable the ignition other than detaching the camshaft position sensor?
DaveCain
Year and Model: XC60 2023
Post by DaveCain »
I just completed installing the head and the rest of the surrounding pieces (it took 3 hours to install the PCV banjo bolt):x. I'm about to start the engine and want to oil prime it first. To disable the ignition system, the Haynes handbook recommends disconnecting the camshaft position sensor. Is there a way to disable the ignition other than detaching the camshaft position sensor?
Has thanked: 2200 times
Been thanked: 1852 times
You are in the wrong forum, but a general suggestion would be pull the fuel pump fuse. No pump + no fuel. Haynes suggestion works if the plug is easy to access.
Neil
Been thanked: 4065 times
No need to oil prime it either, especially if you use assembly lube on the relevant surfaces.
Just check timing by turning over by hand twice.
