Is there a way to disable the ignition other than detaching the camshaft position sensor?
I just completed installing the head and the rest of the surrounding pieces (it took 3 hours to install the PCV banjo bolt):x. I'm about to start the engine and want to oil prime it first. To disable the ignition system, the Haynes handbook recommends disconnecting the camshaft position sensor. Is there a way to disable the ignition other than detaching the camshaft position sensor?
- Has thanked: 2197 times
- Been thanked: 1850 times
You are in the wrong forum, but a general suggestion would be pull the fuel pump fuse. No pump + no fuel. Haynes suggestion works if the plug is easy to access.
Neil
Neil
- Been thanked: 4064 times
No need to oil prime it either, especially if you use assembly lube on the relevant surfaces.
Just check timing by turning over by hand twice.
- 981 Views
Last post by kallekula
- 2595 Views
Last post by Luzanov345
- 2938 Views
Last post by RickHaleParker
- 1879 Views
Last post by xHeart
- 2159 Views
