1998 V70 AWD 33 Step Timing Belt Replacement with Photos
songzunhuang
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 30 times
Post by songzunhuang »
Thanks for an excellent post. I thought I would add a few pictures to the thread.
First is the timing marks. I was all worried that mine would be hard to find, but as it turns out it was super easy. In fact it appears that my timing belt must have been serviced before (although I don't recall).
Here's my timing marks. Not only are the factory marks clear at 1 o'clock (left) and 11 o'clock (right), but it looks like someone painted the white marks on the cover and the cam gears.
Down below on the crank, I had two very clear keys as well. First the crank pulley mark lines up with the belt when the upper marks are aligned.
Then if you look in the engine block, you can see the cast arrow that points to the valley between the two notched teeth on the gear itself. Mine was pretty clear so I grabbed this snapshot to share.
The timing belt cover was a bit of a pain for me. Some threads says that you can only get to the bolts by feel. I jacked the car up and found them pretty easy to locate, although the lower bolt gave me fits.
Belt Guard Bolts.png (454.11 KiB) Viewed 1424 times
Finally, there's the water pump. I read all kinds of tricks of getting the gasket to stick in pace with some sealant when re-installing the pump. Mine was much easier than that. There's 2 locator pins on the engine block. I just used these to hang the new gasket then placed the pump on top of it. It was really simple.
Screen Shot 2014-12-26 at 8.55.45 PM.png (565.7 KiB) Viewed 1424 times
Anyhow. I hope these help some folks out.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
regent
Year and Model: 2015 XC60 T5
Been thanked: 12 times
Post by regent »
Awesome pictures, thanks a lot!
I use some hand-made plastic sharp tool to scrape the old water pump gasket residue from the mating surface on the block and just a trace amount of grease on the new gasket. The locating dowels will help the gasket stay put, and the lubricant helps it seat better. Just take my time and torque the seven mounting screws gently and slowly (in two or three increments). I also check the final torque once again just before tensioning the new belt, and then re-fill with new coolant. Never had a leak.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
dwillburn
Year and Model: 1998 v70 xc
Post by dwillburn »
MANY THANKS FOR TAKING THE TIME TO MAKE THE STEP BY STEP INSTRUCTION - TRUELY HELPFUL!! :D
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
I haven't read ALL of the comments, but I thought I would mention that the '98 engine in this article did not have variable exhaust valve timing. My understanding is that '99 and later do have this feature, and THAT means at least one sprocket will be SPRING-LOADED. You will be very sorry if you attempt to do one of these later engines without the tool to lock the camshaft sprockets (IPD sells an inexpensive one). How do I know? I did a 2000 S40 without such a tool under time pressure and only a long life of clean livin' got me out of there alive.
All U.S. market models.
All running and on the road.
Has thanked: 1611 times
Been thanked: 4072 times
You don't need the cam lock tool to do a timing belt on a CVVT car - only to remove a cam sprocket.
You do need to understand how to set the moveable sprocket up correctly - which isnt difficult.
Hellhoff
Year and Model: 1998 V70
Post by Hellhoff »
ATTENTION: Water pump torque values in information MAY be incorrect. I followed this instruction to the letter torquing the water pump bolts up to 20Nm when the threads in my engine block gave way. :( Supposedly the value is 17Nm and the aluminum block is very sensitive. Please verify and correct information in original post to avoid anyone else ending up where I am at now!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I also highly recommend an in.-lb. torque wrench (1/4" drive) to torque small fasteners like this.
