Unfortunate new Volvo owner! (98 V70 AWD)
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
Looking good!
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Culito
- Been thanked: 7 times
Not too pretty, but it looks good lit up.
I scrubbed the center console while it was out, it was nasty.
I found a lot of change under the seat and console, so the car only cost me $1597.50!
- Has thanked: 2212 times
- Been thanked: 1853 times
Those small bulbs like the auto-shifter position light are a real pain to repair as they were originally 'welded' by their leads to the pins. Makes it hard to remove and solder a replacement without melting the casing. Looks like you did a much nicer job than I did!
Culito
Thanks, a nice pair of flush cutters makes removal easier (and they are super handy for lots of things)scot850 wrote: 23 Jul 2023, 22:57 Those small bulbs like the auto-shifter position light are a real pain to repair as they were originally 'welded' by their leads to the pins. Makes it hard to remove and solder a replacement without melting the casing. Looks like you did a much nicer job than I did!
I do fine soldering work fairly often, so this wasn't a huge deal. Just make sure the iron is nice and hot, so you don't have to spend much time on the pin.
Culito
I'm trying to track down the cause of the cruise not working on this thing.
I replaced the brake light switch ($65 official Volvo!!) to no avail.
Turns out it's fairly simple to disassemble the switch and clean the two identical sets of contacts.
The vacuum pump and everything works fine, so I guess I'll check this relay thing under the hood next.
The other day the thing stuck in first gear - turns out the TPS failed. Always something.
I'm no electronics expert, but could the TPS not affect the cruise control?
When you say the cruise vacuum pump works fine, have you physically checked it? If I recall they mount under the battery tray. I had one where the pump had a hole in the casing due to leaked battery acid, and another with a cracked casing.
Culito
TPS is fixed with a new unit, seems to work / shift fine now.
The cruise has never worked. I can make the vacuum pump pull the pedal with some jumpers. The switches on the stalk seem to test fine. Repaired the ABS unit. New brake switch..
I found a site that goes through some troubleshooting steps, but all the pics are missing.
Not sure how to test the relay unit (Hella 1378076)
I'll keep poking around!
Culito
Current goings on:
Front rotors installed. Rear bumper cover had come loose in the past, and the exhaust melted some parts, causing alignment issues. Got that squared away and reinstalled. Time for the front to go down. New spring versus old. Strut seemed okay. New strut bearings, top spring cups, bump stops. Fixed another broken ABS wire. Current stance. Rear may need to go down just a hair.
Wow, you have been really busy knocking the challenges out. Are those aftermarket lowering springs?
Culito
They are, the previous owner had bought a bunch of parts for it, including the springs.scot850 wrote: 15 Aug 2023, 16:52 Wow, you have been really busy knocking the challenges out. Are those aftermarket lowering springs?
It's been fun to work on!
