The back flange is basically the same as the front. Try soaking it with penetrating oil around the join over night and then tapping the sides with a cold chisel at a forward angle to see if it will help to come loose.
If the rubber center bearing surround is good and not split you are a lucky person and sounds like it is good for another round.
Late 1998 V70XC driveshaft removal
- Has thanked: 2215 times
- Been thanked: 1853 times
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 71 times
No splits, I'll consider myself lucky for that! Im just going to rebuild the front joint as it stands, if the clicking persists I'll tear it back down, it really wasn't that difficult to get to this point. I'm coating the front flange in anti-seize though.scot850 wrote: 17 Aug 2023, 17:39 The back flange is basically the same as the front. Try soaking it with penetrating oil around the join over night and then tapping the sides with a cold chisel at a forward angle to see if it will help to come loose.
As annoying as this first gen AWD is, it works, I took it down a muddy road and felt the rear push me out, I probably would have just been spinning tires on a FWD.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
The main complaint I have read about with the first gen AWD system is a slight delay before it kicks in when needed. Other than that it works ok.
jsrnsis
Getting the joint apart wasn't easy. I don't see how you could do it without being destructive. There is a snap ring behind the backing plate of the assembly that retains the joint on the shaft. The backing plate is thin metal, I was able to wedge a small pick and a screwdriver through the bolt holes to pop it off. A couple of whacks with a rubber mallet should separate the outer race of the CV from the boot, and then the race can be removed. The center of the CV joint sits tightly on splines on the driveshaft, I used a 3" 2 jaw puller from harbor freight to pull it off the shaft after removing the bearing balls. The boot should slide off the shaft easily once the oetiker clamp is pried off.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
It’s a viscous coupling, so power is always sent back to the rear, and there’s no delay whatsoever. That’s first gen Haldex you’re thinking of. The downside of this system is horrible fuel economyscot850 wrote: 17 Aug 2023, 22:50 The main complaint I have read about with the first gen AWD system is a slight delay before it kicks in when needed. Other than that it works ok.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- V50M66
Be careful which shaft you get, there’s 3 variants - early ‘98, late ‘98 and ‘99, and ‘00. If the front joint won’t pop, there’s a pair of holes on the backside of the angle gear flange that you can put an Allen key in and pry to pop it. Mine just came right out. It’s best to take the whole shaft out of the car in one go
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Sounds like the shaft is already out of the car and disassembled
jsrnsis
The bolts that came with the kit I bought are longer than the original and stick out of the back of the angle gear flange. I didn't want to run into a problem down the road where the exposed thread rusted and made it difficult to get these Allen head bolts out, so I reused the original bolts, that I had kept in their original placement relative to a mark I made on the flange.
My bolts were clean, and the Allen socket heads were clear, but yours may be crusty and not worth re-using.
I definitely recommend putting the car up with jackstands on all four corners so all wheels spin free so you can put the transmission in neutral to spin the shaft to whatever position you need, and then put it in park with the e-brake on when you need to put any torque on it.
A bit ratchet with a 6mm Allen 1/4 bit will make removing/replacing the bolts after they're broken free a lot easier. Harbor Freight sells one as a "ratcheting right angle screwdriver" for $3 but it doesn't come with any Allen bits.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
- Has thanked: 1613 times
- Been thanked: 4078 times
Dab them up with antiseize and they will be fine. Originally these were used to balance the shaft but we have seen enough of them running unbalanced with no problems that probably is overkill
Volvo specs a bunch of colour coded bolts for balance but I’m pretty sure they aren’t available any more
Never had an issue. I have only ever seen 2 different lengths and never seen one yet with different length bolts in the same flange. I have re-used all of mine and have a whole bunch more from pulling AWD stuff out of junkyards!
The most important thing to do is to clean out the hex heads. I use a pick to get it clean.
- 17 Replies
- 3440 Views
Last post by cn90
- 15 Replies
- 3660 Views
Last post by shiloh51933
- 569 Views
- 972 Views
Last post by zmf
- 1384 Views
