2015 S60 T5 - 4 cylinder
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
RickHaleParker
Been thanked: 958 times
Re: 2015 S60 T5 - 4 cylinder
Post by RickHaleParker »
With the camshaft lock tool. It goes in the slots on the back of the cams. The slots are offset so there is no way to get it wrong. That will align the cams to the head.
dmd4003
Year and Model: 2015
Has thanked: 3 times
Post by dmd4003 »
Ugg, I ordered the timeing kit 5 days ago, received email they are out of stock.
RickHaleParker
dmd4003 wrote: 23 May 2020, 06:44 Ugg, I ordered the timeing kit 5 days ago, received email they are out of stock.
I got one like that recently. The vendor sells through multiple channels. The inventory they post on eBay is not exclusively reserved for eBay sales. I imminently filed a claim for a refund and ordered from a second source. On top of that your order has five days of floating the payment. No five stars for that vendor.
Almost as bad as eManualonline. They said they would refund my money if I snail mail the downloaded pdf to London UK. Got Paypal involved Paypal got my money back.
RickHaleParker
Preloading turn fully clockwise Tighten nuts to 25 Nm.
See attached PDF for the rest.
Timing.pdf
(549.97 KiB) Downloaded 435 times
craiger
Year and Model: 2016 S60
Post by craiger »
Follow-up question: I see how to align the cams and the crank, but you also mentioned a pre-load on the cams. What is this?
Notavolvofan
Year and Model: 2016 XC90
Post by Notavolvofan »
craiger wrote: 04 Dec 2023, 15:52 Follow-up question: I see how to align the cams and the crank, but you also mentioned a pre-load on the cams. What is this?
Did you have any luck? I’m currently working on a 2016 XC90 I replaced burnt valves in. I have the cams locked in the rear but the tool for the gears seems to be off per the factory pictures.
Kwheeler
Year and Model: 2015 xc60 t5
Post by Kwheeler »
Notavolvofan wrote: 12 Dec 2023, 11:39
Did you have any luck with your 90? I’m reassembling one right now and trying to find info on the cam gears. The pics previously posted make it seem like only the intake gear is unlocked? Do both get unlocked? Did you take any pictures?
