control arms
mrbrightside2009
Year and Model: 96 850 turbo
Post by mrbrightside2009 »
96 850 turbo...mine seems to have the 4 bolt configuration for the control arms...i am only seeing that setup for s70's online... and i am only seeing 2 bolt configuration for the 850's...do i just buy the ones listed for the s70?
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
The 850ies had 2 bolts towards the frame and a removable ball joint for the early years. The Diesel 850ies had a different mounting pattern towards the frame, could bel 4 bolts.
1996 855 R,
2010 V70 D5,
Has thanked: 2211 times
Been thanked: 1852 times
We didn't get diesels this side of the Atlantic unless possibly private imports. So if you have owned the car from new then it is an anomaly if it has a 4 bolt control arm. Can you post a picture for us?
If you have not owned the car from new, it may have had an accident and someone fitted a later front subframe from a V/S/C 70 P80.
If that is the case then a regular 4 bolt part should be fine.
Has thanked: 1611 times
Been thanked: 4075 times
I think you have a swapped subframe. You need to match bolt pattern of course.
mrbrightside2009
Back on this again...so I am going to post a pic of this arm...definitely looks like the 4 bolt configuration if someone can confirm this. I snapped a quick pic last night did not really look under there too well.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Yup. 4-bolt. Are the bushings for the subframe aluminum? Someone has probably swapped in a C70 convertible SF.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
mrbrightside2009 wrote: 25 Jan 2024, 05:54 Back on this again...so I am going to post a pic of this arm...definitely looks like the 4 bolt configuration if someone can confirm this. I snapped a quick pic last night did not really look under there too well.
4 bolt.
8628497 and 8628498
The usual warning about avoiding URO anything.
foggydogg
Post by foggydogg »
Agree with the others, subframe swapped. C70 or an AWD platform. Raising the motor up a bit helps with access to the bolts; pack your patience, it isn't a ten minute job.
foggydogg wrote: 25 Jan 2024, 07:12 Agree with the others, subframe swapped. C70 or an AWD platform. Raising the motor up a bit helps with access to the bolts; pack your patience, it isn't a ten minute job.
I quoted an hour for a 4 bolt control arm once, based on the two bolt design, and the Creator humbled me.
