2005 xc70 WHAT IS this part??!
markdbenz
Year and Model: 2005 XC70 & 2012 S60
Post by markdbenz »
Changing xc70 plugs
Dropped socket in back of engine
Had to remove lower plastic pan
Found socket
AND
What looks like a main bearing type half round casting w bolt hole on each end
About 6 in long
Any idea what it is???[img][/img]
And where it goes???
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
looks like it is coming from the passenger axle shaft carrier bearing housing.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
markdbenz
Post by markdbenz »
Ack! Yes it does look like ones in online diagrams! Thank you very much. Any idea what the 2 bolts are??
markdbenz
Post by markdbenz »
Yup
See pic. Thanks again!
Any ideas how to get to it w/ wrench etc?[attachment=0]IMG_7086.jpeg[/attachment]
Antoine240bk
Seems to be a flange screw M8 x 35mm, pn: 988983
https://www.fcpeuro.com/products/volvo- ... lvo-988983
spinard
Year and Model: '04 V70R, '16 XC70
Been thanked: 3 times
Post by spinard »
I guess it goes without saying that the screw does not go with the axle bearing. :)
I'm assuming your two bearing bolts rattled out and are gone. They are M8x35 flange screws, Volvo part #982797. If recall they are angled such that they are pretty easy to get to with like a 6" ratchet extension. 12mm or 13mm I think.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Was this assembled by Boeing?
spinard
Post by spinard »
BlackBart wrote: 28 Jan 2024, 14:41 Was this assembled by Boeing?
LOL
markdbenz
Post by markdbenz »
I used to work for Lockheed space, so no. Good joke though!
Factory as far as I know…
Owned car since 2016
Assume I take off the wheel and there it is?
markdbenz
Post by markdbenz »
Btw plugs were pretty bad
