Started the car today for the first time since 30th September last year. For some strange reason it had a very noisy hydraulic tappet which it never had before when left over winter. A few minutes later it was all quiet again and back to normal
My plan for today was to not start the engine but when I looked underneath the car I noticed an oil leak coming through the sump cover splash guard, so I decided to put the car on the lift to investigate. It turned out to be the sump plug was weeping slightly, I did an oil change last year and fitted a new washer, but it decided to leak. I've tightened it up a bit more and I'll keep a close eye on it as the oil has only done about 1400 miles and I don't want to remove the sump plug just now.
While I had the sump splash guard off I decided to fit some rivet nuts and bolts instead of the self tapping bolts I previously fitted. I don't have the fancy tool for fitting them but it's easy enough with a nut/bolt/washers and a couple of spanners to insert them.
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
hi the noisy tappet is normal esp if left unused for a while all that happens is the oil drains out of the tappet and they make a noise till the oil pump fills them up again,cold oil takes a little while to reach that high up the engine,as long as it goes quiet quick once running all is good.good luckP80GLT wrote: 24 Mar 2024, 12:48 Started the car today for the first time since 30th September last year. For some strange reason it had a very noisy hydraulic tappet which it never had before when left over winter. A few minutes later it was all quiet again and back to normal
- Has thanked: 2210 times
When we restarted my friends 96 850 10V NA last year it has been sitting for a few months. Sounded like a bag of nails. Once we drove it about half a mile it suddenly went quiet. Then it just purred. Not bad for a car with somewhere around 500,000km!
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I let mine sit untouched open to the element, no windshield, passenger windows busted for literally 1 year. I changed the battery abd she started right up and drove right out of there. Tapped like crazy until built oil pressure.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.P80GLT wrote: 24 Mar 2024, 12:48 Started the car today for the first time since 30th September last year. For some strange reason it had a very noisy hydraulic tappet which it never had before when left over winter. A few minutes later it was all quiet again and back to normal
That's a great idea on the rivet nuts. Have you ever drained the oil and put in a new filter with oil in the filter cartridge before storage, then add oil right before firing it up. Perhaps the oil going in front the top would eliminate the dryish start?
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
I'veever tried that, not sure if it would be any better but I like your thinking. Oil light went out immediately on start-up, it's never clattered before when left over the winter so unsure why it has done it this time. Oil level was on the mark, the oil in the splash guard would be no more than a couple of teaspoons full, not even enough to drip onto the garage floor. I wonder if filling with 5W instead of 10W would maybe help a bit. More research before tucked away in the autumn.MoVolvos wrote: 24 Mar 2024, 17:02 Have you ever drained the oil and put in a new filter with oil in the filter cartridge before storage, then add oil right before firing it up. Perhaps the oil going in front the top would eliminate the dryish start?
- MoVolvos
.P80GLT wrote: 25 Mar 2024, 01:18I'veever tried that, not sure if it would be any better but I like your thinking. Oil light went out immediately on start-up, it's never clattered before when left over the winter so unsure why it has done it this time. Oil lever was on the mark, the oil in the splash guard would be no more than a couple of teaspoons full, not even enough to drip onto the garage floor. I wonder if filling with 5W instead of 10W would maybe help a bit. More research before tucked away in the autumn.MoVolvos wrote: 24 Mar 2024, 17:02 Have you ever drained the oil and put in a new filter with oil in the filter cartridge before storage, then add oil right before firing it up. Perhaps the oil going in front the top would eliminate the dryish start?
Would be an interesting experiment if you decide to give it a go. Just don't forget to add oil when putting it back into service.
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Spent the morning reattaching Blue Steel’s AC condenser to the radiator.
I got everything buttoned up, and then got an odd-sounding crank, no start. I tried a new battery and fuel pump relay, but it only cranked and sputtered before stalling. We were planning a trip to Pennsylvania and DC for spring break this week, so I’m glad it happened before we took off, but I’m puzzled.
Any suggestions welcome!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 316 times
- Been thanked: 531 times
Are you getting fuel? Almost sounds like a washed down cylinder.
- MoVolvos
.brunocerous wrote: 25 Mar 2024, 11:36 Spent the morning reattaching Blue Steel’s AC condenser to the radiator.
Could be fuel, spark or timing. You want to be sure not to crank too many times in case you are flooding the cylinder and then the CAT. Turn the key to Position 2 and push the Schrader valve to see if there is fuel squirting out.
Next check the cap & rotor. If it seems to look okay then remove the 2 screws to expose the injectors. Unplug the connectors and with the key in the Position 2 test to see if you have Voltage at the leads. Polarity doesn't matter when checking. If you have voltage then check spark to the plugs.
Timing would be the last to check.
