Do you think that a rust penetrant or lubricant would help it out? If it's even possible to get that stuff in there if the ball joint is installed so tight. what if somebody submerged or soaked the ball joint part in the lubricant. Wonder if that helpserikv11 wrote: 03 May 2024, 10:14 Last control arm job I did, on the green XC70, I could not get the old ball joint out from one side even after pounding it over and over with the air hammer. Started to chew up the knuckle all around it. I gave up and put it back in, maybe will need to get a new knuckle in order to get a new ball joint in there.
DIY Ball Joint Installation Tool
- FMradio
- Year and Model: 2006 S60
- Has thanked: 55 times
- Been thanked: 8 times
- Has thanked: 311 times
- Been thanked: 817 times
I tried both heat and penetrant. They should help, yes!
Using anti-seize on the install helps for next time, but doesn't solve the stuck one.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.erikv11 wrote: 09 May 2024, 21:59 I tried both heat and penetrant. They should help, yes!
If possible cut the edge off the ball joint and drill into the side downward to relieve tension? Photo borrowed from link.
https://www.suspension.com/moog-k80700
Not a bad idea, thanks.
I ran out of time, needed to complete the job on both sides in one night, so I put it back together with the old ball joint. Ball joint was old but not loose. I'll have to get back in there and fix it, however.
Yeah, I'm not likely to drill anything except as a last resort. But the chisel is a lot more work than zipping it out with an air hammer, which was foolproof for the first five I did. The question is, what will actually work?
Anyway I'm not digging into that any time soon, have a long list projects ahead of it.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
All metal moves when it is liquid.
I got frustrated with my last one and took the knuckles and ball joints to my local shop, darn guys installed them for no charge.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 15 Replies
- 3712 Views
- 11 Replies
- 3158 Views
Last post by theWIFES_S70
- 598 Views
- 4196 Views
Last post by ndphotonl
- 12 Replies
- 1940 Views
Last post by erikv11
