If you try to rebuild the pump, clean the pump before disassembly and keep everything very clean. Not just engine part replacement clean, but super clean.
98 v70: steer me to the steering rack replacement topic
- Has thanked: 927 times
- Been thanked: 1000 times
Re: 98 v70: steer me to the steering rack replacement topic
- CIK7
- Has thanked: 328 times
- Been thanked: 87 times
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 94 times
- Been thanked: 39 times
- CIK7
https://www.ebay.com/itm/254903783538
I tried to add an Amazon https://www.amazon.com/Edelmann-8900-St ... 393&sr=8-1
jmartin919
Thanks. Do you plan on doing this?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- CIK7
Yes Ill try to remember to set up my bridge cam with a tripod to document it.
- CIK7
This seems to be getting more complicated and confusing. I read this viewtopic.php?t=17902 for correct rack. Of course I already bought this rack https://www.rockauto.com/en/moreinfo.ph ... 7388&jsn=9 without knowing if it was a CAM/TRW or SMI so possibly too late. My product code is a 5, therefore requires SMI. However, I called BBB industries (mfr of the rack) and they said SMI is NLA (on market) and is superseded by CAM/TRW which is fully compatible with SMI applications. Can someone please clear this up for me?
BTW I bought this unit on clearance for $112+shipping=$150, no core
Edit1: I found this after I found the VOLVO logo and the part number 34010753 LH. It specifies both TRW and SMI. https://www.autodoc.co.uk/car-parts/oem/34010753lh
Edit2: LOL after 2 hours of looking on the unit and searching the internet, I finally found TRW in small letters on the side underneath the VOLVO logo.
Since at least the mid 1970's Volvo has used multiple suppliers for brake and steering components.
- chrafael
- Year and Model: 1998 v70 GLT
- Been thanked: 10 times
I've used the Edelmann kit and it seems to be working well enough. I would disassemble the pump first because it the vanes are broken or the body is too heavily scarred then it's a tosser. Be warned that the pump body is spring loaded against the retaining lock ring. Also, carefully note the position of the end plates and body in relation to the housing as the assembly floats on two dowel pins and is designed to rotate a few degrees. Take pictures and don't confuse which end plate goes where or which way they face. Otherwise an easy, straightforward job.
