98 v70: steer me to the steering rack replacement topic
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
If you try to rebuild the pump, clean the pump before disassembly and keep everything very clean. Not just engine part replacement clean, but super clean.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
CIK7 wrote: 12 May 2024, 13:05 Are all 4 front subframe bushings the same?
I think one of them used to be a different p/n decades ago, but was superseded by 4 identical ones.
1996 855 R,
2010 V70 D5,
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Clemens wrote: 14 May 2024, 00:13
:P :lol:
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
CIK7 wrote: 13 May 2024, 18:06 I found out that its possible to rebuild the power steering pump. I found the kit for it.
Care to share?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
CIK7
Post by CIK7 »
jmartin919 wrote: 14 May 2024, 06:03
Care to share?
https://www.ebay.com/itm/254903783538
I tried to add an Amazon https://www.amazon.com/Edelmann-8900-St ... 393&sr=8-1
jmartin919
Thanks. Do you plan on doing this?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
CIK7
Post by CIK7 »
jmartin919 wrote: 14 May 2024, 07:19 Thanks. Do you plan on doing this?
Yes Ill try to remember to set up my bridge cam with a tripod to document it.
CIK7
Post by CIK7 »
This seems to be getting more complicated and confusing. I read this viewtopic.php?t=17902 for correct rack. Of course I already bought this rack https://www.rockauto.com/en/moreinfo.ph ... 7388&jsn=9 without knowing if it was a CAM/TRW or SMI so possibly too late. My product code is a 5, therefore requires SMI. However, I called BBB industries (mfr of the rack) and they said SMI is NLA (on market) and is superseded by CAM/TRW which is fully compatible with SMI applications. Can someone please clear this up for me?
BTW I bought this unit on clearance for $112+shipping=$150, no core
Edit1: I found this after I found the VOLVO logo and the part number 34010753 LH. It specifies both TRW and SMI. https://www.autodoc.co.uk/car-parts/oem/34010753lh
Edit2: LOL after 2 hours of looking on the unit and searching the internet, I finally found TRW in small letters on the side underneath the VOLVO logo.
Since at least the mid 1970's Volvo has used multiple suppliers for brake and steering components.
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
I've used the Edelmann kit and it seems to be working well enough. I would disassemble the pump first because it the vanes are broken or the body is too heavily scarred then it's a tosser. Be warned that the pump body is spring loaded against the retaining lock ring. Also, carefully note the position of the end plates and body in relation to the housing as the assembly floats on two dowel pins and is designed to rotate a few degrees. Take pictures and don't confuse which end plate goes where or which way they face. Otherwise an easy, straightforward job.
