Volvo V70 3.2L Air Intake Hose Pipe Tube Duct question
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
senornose
Year and Model: 2010 V70
Post by senornose »
2010 V70
Hello,
I recently flushed the ATF on my Volvo. As I was removing the filter box, this appendage broke off Image. Upon further inspection it had been glued on, so this was not the first time it happened. No idea when it happened initially. I tried to follow in kind and glue it back on. It came off recently, CE light illuminated, and the following code was posted ECM-P017100 System Too Lean (Bank 1). While running the engine I put a temporary 'cap' over the hole, a noticeable ECU adjustment took place, cleared the fault code, and it's remained off.
My question is: What is that lobe/appendix even for? Moisture? There are no drains that I noticed, no sensors or filters.
The car is running fine. My first thought was this could be a universal part and more important for other models.
Thoughts? If it's an important part of that assemblage I'll buy a new one, but if not I would consider installing a more robust cap.
Thanks!
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 184 times
Post by pgill »
senornose wrote: 18 May 2024, 14:49 2010 V70
My question is:
Noise reduction.
It makes the intake sound more pleasant.
Form over function and all that.
Good luck
Paul
