Blue smoke from exhaust
radek93
- Year and Model: S70 98
- Has thanked: 2 times
- Been thanked: 3 times
B5254t. What does blue smoke from the exhaust mean? It only smokes when the engine is warm, when it runs for several dozen seconds at idle speed and after increasing the speed. It does not smoke when the engine is cold immediately after starting, it does not smoke when accelerating, it does not smoke when engine braking and then accelerating. The oil filler cap is gently sucked on when the engine is running. So PVC seems to work well.
- Has thanked: 1850 times
- Been thanked: 1712 times
The 2 main issues are hardened valve stem seals, or worn turbo seals.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Or wrong viscosity oil(read too thin)..but like Neil said...turbo or valve stem seals.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- foggydogg
- Has thanked: 83 times
Since it doesn't smoke when accelerating that generally eliminates rings, and based purely on age, if the car hasn't had valve stem seals yet, they are likely age-hardened. A suggestion would be to change the oil - follow the recommended viscosity in the owners manual, the folks who designed the car do know best - and see if it has any effect on the behavior. Avoid all the Magic In A Bottle, that stuff is good for draining your wallet and not much else.
