V70 '98 crank, no start. Out of ideas [Fenix, IMMO3]
MotorTheresa
Year and Model: V70 1998 B5252F/S MT
Has thanked: 33 times
Been thanked: 15 times
Post by MotorTheresa »
jmartin919 wrote: 15 Jul 2024, 08:05 If you roll down a window, lock the car, then pull up on the unlocking pin at the open window does the alarm go off?
Nope, stays quiet. I have never heard the alarm.
Few things to note:
1. front passenger door contact does not recognize door is closed as the micro switch does not push back enough.
2. Dashboard LED is always dark
3. I can't lock the vehicle with the in car lockbutton. Pins will go down but come back up immediately. Closing with key works fine tho.
G'dnite
-Chris
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
The alarm system won't activate if all the doors, hood and hatch aren't detected closed.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
MotorTheresa
jmartin919 wrote: 15 Jul 2024, 16:20 The alarm system won't activate if all the doors, hood and hatch aren't detected closed.
Ok, that's consistent then.
I could access the lock and manually put it into "closed" and check if the car activates the alarm.
(Noob question: Is every EU spec '98 V70 equipped with alarm?)
Thx!
MotorTheresa
Got the OBD dongle today. Works charms with the app.
Going to put some logs here:
850sum.txt
(490 Bytes) Downloaded 62 times
850log.txt
(9.28 KiB) Downloaded 54 times
jmartin919
Ignition switch problem?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
MotorTheresa
jmartin919 wrote: 16 Jul 2024, 13:56 Ignition switch problem?
I have read this too.
Don't have a spare unfortunately but can obtain tomorrow.
Other things I saw:
VGLA live shows central locking non effective
Immo signal NOK while key is detected in ignition lock
What a powerful tool this is <3
-Chris
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Weird question but do all your lights and turn signals function right when you start the car? If you push the key or shake it will they function if they do not as of now? I know a bad switch can cause these not to turn on. Could you be facing an extreme case?
2008 S60 2.5T Auto (Sold)
MotorTheresa
Lights and signals work good.
Still going to try another ignition switch to be sure.
General question:
Does someone know if I'd need to swap both ECM and IMMO if the Immo Module was shot? (That's what I know)
Or can another IMMO Module be repurposed ?
Thx
Chris
Has thanked: 2212 times
Been thanked: 1853 times
I an not sure with EU models as you got shipped keys earlier than us, and with all the updates after 99 that I am familiar with as that is when we got chipped keys. In that case we have to swap everything that stores the Vin#. I'm not sure if the IMMO stores the Vin# or if it just compares info from the key with the ECU. The Vin# in 99 on cars also stored the Vin# in the dash cluster/speedometer cluster on the motherboard. They compare with the ECU too.
When I was having issues with my car, I swapped the cluster from another car. Unfortunately it was a 4 speed auto not 5 speed auto. It made the TCU unhappy. However the car still started so it tells me the IMMO and ECU decide on if the car starts. However, when I tried to use my Vida, it would not connect with the ECU as the Vin# in the cluster did not match.
So in your 98, I am thinking this may be the same. You may be able to keep the cluster, but replace the IMMO and have to have it reprogrammed to the Vin if that can be done. It may require the ECU to have something done, but now I am way out of my knowledge space!
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
10V Engine IMMO3 does not have VIN programmed at all in Engine nor IMMO. I have one of these from 99 year model.
In Scan log i didnt see IMMO Scan. You can send that to my email if feels better.
Good point you noticed from that IMMO Not Okay signal as you checked did VGLA even have IMMO bit set which it didn't. My 10V IMMO3 memory from Fenix 5.2 ECM doesn't have linkage code between IMMO3 and VGLA neither so maybe it is thats why and its normal show then that in Live Data.
