i fixed #1 with an oil/filter change.scot850 wrote: 06 Aug 2024, 15:34 OK, here is the long list. 10 items listed. Now it is possible one may cause another, but there is a lot of diagnostics to be done on top of all the other work. Some may be as simple as possibly cleaning an item and electrical connectors, but at least one means a part replacement, but then 3-4 may be needed:
Fault Codes - (These are Autel codes, but I believe these will also be what Vida would give) :
1) (643A) ECM-643A : Cam Position - exhaust: Signal too low
2) (2810) Permanent fault ECM-2810 : Front O2 (upstream) sensor (HO2S) bank 1 heating : Signal missing
3) (531D) Intermittent Fault ECM-531D : Malfunction indicator lamp (MIL) CEM: Signal missing
4) (280A) Permanent Fault ECM-280A : Front heated O2 (upstream) sensor (HO2S) bank 1 : Faulty signal
5) (3000) Intermittent Fault ECM-3000 : Inlet camshaft sensor : Faulty signal
6) (400C) - ECM-400C : Fuel tank system leakage : Minor leak
7) (6806) Intermittent Fault ECM-6806 : Turbocharger (TC) control system flow fault : Flow too low
(130A) ECM-130A: Air leakage intake
9) (990A) ECM-990A : Idle air trim : Faulty signal
10) (914F) ECM-914F : Throttle valve : Faulty signal
So any suggestions or advice if anyone can see a pattern or if any of the issues could be related your input is appreciated!!
I'm thinking the following actions:
1) Cam Position - Exhaust : The exhaust cam is the only one with a CVVT sensor on it - Remove and clean. Check resistance value, reinstall and see if issue resolves itself. It has the newer style plug connector on it so I may have a good used one worst case Need to compare part numbers
2) O2 Sensor - Upstream - Replace after checking no wire damage
3) Not sure what this is. Is it the warning (check engine) light is missing? It is on.
4) As per 2)
5) Cam Sensor - Is there a separate cam sensor as there is no inlet CVVT solenoid?
6) Emissions system leak - Minor. Will have to smoke the system possibly to find this.
7) TC - Turbocharger intermittent control system fault. Is this a faulty TCU? If so, need to see if I have a spare used one
Intake air leakage - Have to try the brake cleaner/WD-40 spray test or smoke the system.
9) Idle air trim : What/were is this??
10) Throttle valve - Faulty signal - If this means the ETM/Throttle body. It seems really oily, so will require to be remove and cleaned. The refit and see if the issue is still there.
There will still be the possibility of another issue that is not coded. If the cold rough start does not get fixed, may have to test/replace the ETC
So added to all the other issues, the work and cost to return this car to decent and safe condition could be a huge investment in time and money.
#5 cam sensors are on the driver side or transmission end of the cams,
sounds like some general air leaks someplace, smoke em out.
rough cold start is probably the upper o2 sensor heater failure.
