Throttle body questions....
AlanS
Year and Model:
Post by AlanS »
I found several YouTubes on cleaning the TB on my 2006 XC70. Seems like a 'chore'....not really accessible, some knuckle scraping, etc. Given the amount of effort to remove, clean and replace....does it make sense to spend the $290 on a new body? I fear that I will remove, clean and replace...only to find the same issues post work. Do TB's wear out? This car has not cost me much during it's life, I have no issues on spending the $290...but don't want to throw that cash away if not needed. AND....does the car need to be re-calibrated after this cleaning or new unit? I don't have VIDA.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
why spend money on parts you don't need, I would definately spend money on vida.
Has thanked: 1850 times
Been thanked: 1710 times
Go to sponsor Xemodex's website. They have information on installing their replacement throttle body. That may help.
Throttle bodies do wear out. What mileage has the car covered?
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
I cleaned my TB three times before deciding it was finally, actually, dead.
I got a cheap low milage used one from LKQ for about ~$100.
04s60 2.4
04xc70 2.5t
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
Isn't your TB the Bosch one? If it is failing, they are ubiquitous, everywhere.
Rock Auto has them. Difference with Xemodex is the warranty. Mind you, that is for purchaser only of the unit only, not for the lifetime of the part.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Post by XC70Rider »
I replaced the ETM on my 2007 XC70 at 130k miles. The PVC oil was accumulating within the tephlon gears inside the ETM causing the butterfly valve to close slowly which led to a lean A/F ratio. I replaced it with a Bosch OEM and have had no issues since. The ECM will calibrate a new ETM so no programming is needed.
With sythetic oil being thinner than conventional oil I forsee the sythetic oil seeped it's way within those gears. If the PVC system fed straight to the plenum this never would of happened. I'm searching for a used plenum so I can feed the PVC oil directly into it with a tap & die.
