2007 XC70: What should I know about a turbo-ed engine..?
AylmerQc
Year and Model: 2007 XC70
Has thanked: 62 times
Post by AylmerQc »
I've never owned a car with a turbo so what should I be aware of as far as maintenance, things to do and not to do, etc.
Does the turbo kick in at certain rpm or speeds or is it on all the time?
How would I know if there were issues with the turbo?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Quality synthetic 5w40 oil every 5k miles or 6 months.
Turbo is controlled by engine computer via TCV (turbo control valve) that moves wastegate.
Turbo can leak oil, seize or does not develop proper boost.
From my own experience, N/A FWD V70 required like 4-5 times less repairs and maintenance than turbo AWD XC70 =)
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
vtl wrote: 02 Oct 2024, 07:01 From my own experience, N/A FWD V70 required like 4-5 times less repairs and maintenance than turbo AWD XC70 =)
n=2 sample size. Same experience here.
04s60 2.4
04xc70 2.5t
AylmerQc
Post by AylmerQc »
N/A means North America?
Meaning of: n=2 sample size..?
vtl
Post by vtl »
AylmerQc wrote: 02 Oct 2024, 08:22 N/A means North America?
Natural Aspiration.
Sample size of 2 means there're 2 samples in the test set :) I.e. br0dy519 and I share same experience with regard to NA and turbo variants of P2 Volvo.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
the oil drain pipe leaks at the upper gasket or lower o ring.
the rubber coupler sleeve to the charged air pipe seeps oil.
those are common fixable problems,
treat it right with the correct oil and filter, its like a magic carpet .
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I'm on my third turbo Volvo wagon. The first one (1984) was the only one that had turbo problems, but it did not come with water cooling to the turbo housing. The 1994 and the 2004 have been mostly trouble free, smooth, and torquey. Great highway distance cars.
Naturally aspirated means an engine that sucks in air to fuel the combustion. A turbo is one that pushes compressed air into the combustion chamber to make additional power. (More Air + More Fuel = More Power). But it makes more heat, hence differences in cooling systems and "intercoolers" to lower the temp of dense, compressed air.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
The high pressure turbo engine (the 2.3 Liter T5) appears to start making boost about 3000 RPM. Easy acceleration and steady 70 MPH keeps the turbo mostly off boost. Above 3000 RPM, the fun starts and the car MOVES.
The turbo engines do seem to take more maintenance. The turbo itself, the intercooler and hoses, and more vacuum hoses are added for the turbo. I own a 2001 V70 T5. It is fun to drive.
vtl
Post by vtl »
volvolugnut wrote: 02 Oct 2024, 18:50 The high pressure turbo engine (the 2.3 Liter T5) appears to start making boost about 3000 RPM. Easy acceleration and steady 70 MPH keeps the turbo mostly off boost. Above 3000 RPM, the fun starts and the car MOVES.
2.5T has it early, at 1500 RPMs. If everything is right with it.
Has thanked: 311 times
Been thanked: 817 times
br0dy519 wrote: 02 Oct 2024, 07:32
I agree! So counting volvolugnut's post, add me to the list and n=4. The fact that the non-turbo (N/A) engine bay is much easier to work in contributes to the perceived difference.
Yet the turbo is so much more fun to drive that I don't think I would ever buy another one of these cars in non-turbo.
Issues with the turbo itself are extraordinarily rare. Main things are (1) use good oil see vtl's post and (2) be sure to keep on top of PCV maintenance and (3) be prepared to replace the large diameter rubber intercooler hoses about 180k miles when the hoses start turning to mush. Oh and there are several extra vacuum lines, be on the lookout for older, failing, decayed rubber vacuum lines.
