So I stumbled upon a '98 V70 GLT that is missing its head due to overheating. Head was removed years ago and is now MIA..
My questions are:
Do the low pressure turbos and the high pressure turbos use the same head ? That is do they both have sodium filled exhaust valves.
And if I'm replacing the head, can I put on a high pressure turbo ? A tune goes without saying.
Head compatibility Topic is solved
- Has thanked: 2656 times
- Been thanked: 1248 times
IIRC on 850s only turbos had sodium valves... I don't know if it changed for the 70s.
Here's a good thread viewtopic.php?p=333659#p333659
- Has thanked: 293 times
- Been thanked: 765 times
Yes: 15g turbo, white injectors and tune. Did that on mine and been running that way for 100k miles and 11 years now. Bottom end is getting tired, though.Sveedy wrote: ↑05 Dec 2024, 15:25 So I stumbled upon a '98 V70 GLT that is missing its head due to overheating. Head was removed years ago and is now MIA..
My questions are:
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Well for $125 delivered to my door I couldn't say no. Door tag says 8/98, but titled as '99. So I don't know if that matters if I'm replacing the head and intake anyway.
Pictures coming as soon as I can work out the current feud between my phone and laptop.
1999 V70 GLT
1999 V70 GLT
A 99 is a pretty different car and much less desirable IMO. But for $125 delivered ... !!!
Looking forward to updates regardless
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Sveedy
That was my thought exactly. But I called the local salvage yard before I bought it. They'll come pick it up and give me $225, so this is probably the last time I'll be able to sell it at a profit.
Is there anything different with the block that would prevent me from putting a different head, intake etc on it, along with a different tune ?
1999 V70 GLT
1999 V70 GLT
- Sveedy
I guess all I had to do was look...
https://www.matthewsvolvosite.com/98-99 ... fferences/
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1506 times
- Been thanked: 3820 times
Also see the “ bastards thread” with focus on the 98 > 99 changes
Note the ETM angst has evolved to a $150 eBay search for the latest used contactless ETM body from Volvo, not the $1000 poke on the eye of before. Coincidentally about the price of cap , rotor, and plug wires you don’t have to buy every 100k
ETM issues are covered in the ETM room forum below
I have three 99s so I have a backup ETMs for both turbo and NA
- 1034 Views
Last post by matt122s
- 549 Views
Last post by Glencoeteen
