I will be changing the fuel pump on my 1999 S 70 GLT as a maintenance measure. I am also changing the fuel pump gasket, and want to change the submersible fuel pump hose ( the small high pressure hose). Can some one give me the part number for that hose? or the dimensions so i can get a similar hose from amazon or the local auto store?
Thanks much,
Ashish
Fuel pump immersible hose
- Has thanked: 1611 times
- Been thanked: 4071 times
I have a pump out so I’ll try take a picture or two today with numbers on that hose. You can also reuse it with good clamps, oetiker are best
- Has thanked: 311 times
- Been thanked: 817 times
I've replaced that hose a couple times on P80 cars like yours. You can use generic, submersible fuel line hose, 5/16 ID. You need about 4 inches for one fuel pump but don't take my word for it, measure it as you don't want to be short. Be sure it is clamped well, I have also had this hose come unclamped before.
I used Gates 27093 and it was not cheap. Currently Amazon shows it for $40/foot (!!), but on eBay it's $12/foot (but is it real or is it counterfeit?). I bought a one foot length in 2017 and it has fixed two fuel pumps so far, I know there is one piece left but not sure if it's long enough to do another pump.
I've changed a lot of those P80 fuel pump gaskets and I will absolutely only buy/use Volvo branded now. Be careful not to let an edge get folded when installing.
- DennisCA
- Year and Model: 1996 850
- Has thanked: 6 times
- Been thanked: 70 times
I bought submersible fuel hose from a physical store and it was IIRC 20 euros per meter when I rebuilt the fuel pump for my Saab.
I wouldn't buy a thing like this online, never know if you get the real thing. Amazon and Ebay are full of counterfeits.
454cid
- Has thanked: 151 times
- Been thanked: 139 times
Any reason why? I would never change an electric fuel pump out if it still was working fine. New autoparts may not last as long as the original. I suppose if you know it's already been replaced with a cheap product, that might be reason enough.ashvolvo wrote: 05 Feb 2025, 03:49 I will be changing the fuel pump on my 1999 S 70 GLT as a maintenance measure. I am also changing the fuel pump gasket, and want to change the submersible fuel pump hose ( the small high pressure hose). Can some one give me the part number for that hose? or the dimensions so i can get a similar hose from amazon or the local auto store?
Thanks much,
Ashish
The hose is likely sold by the foot, or possibly in a pre-cut generic length. It'll be a matter of buying the correct diameter and cutting to length. It will be expensive compared to other types of hose. I've never had to buy it, as all electric pumps I've installed were a unitized contraption that came internally plumbed.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I haven’t changed a fuel pump in any of my 4 p80 99s with 250k, 260k, 180k, 105k. I did on my 99 awd at 150k
Thesis: keep fuel level above 1/4 tank
100mm long , barb is 8 mm
I used Gates barricade
About $4/foot in 2025 USD
https://www.amazon.com/gp/buyagain?ats= ... bia_item_1
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
I've also used Gates 27093 after issues with some aftermarket hoses (that came with expensive known brand aftermarket pumps...) and no issues, apart from being expensive !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- 21 Replies
- 17740 Views
Last post by cn90
- 21 Replies
- 2559 Views
Last post by RedBrickCollector
- 42 Replies
- 12184 Views
Last post by Maestrours
- 5130 Views
Last post by wizechatmgr
- 16434 Views
Last post by Richard99
